Aftermarket Double Din Head unit
jimmy S3 Dec 9, 2008
  1. jimmy S3
    jimmy S3 Member
    99
    I ve seen a double din kenwood sat nav/dvd/cd player and wondered could it be fitted to my S3 with concert stereo, would i have to get a plastic panel to go round it and would the colour match. Or should i just get OE sat nav
  2. HODD
    HODD Member
    115
    I have the kenwood sat nav dvd double din and I had to use the new a3 double din stereo surround and modify it as you cant get one for our model.
  3. benr
    benr Member
    819
  4. HODD
    HODD Member
    115
  5. jimmy S3
    jimmy S3 Member
    99
    thats exactly how i want it, mines the single concert stereo if i move the climate control down will the double din stereo fit in or will i have to get a double din cage, what panel did ya use
  6. S£
    S£ Member
    684
    don't quote me on this but i do belive you can't just move the climate unit down, the one that sits in the middle is a different part no to the one at the bottom. I think it's slightly smaller as the dash curves in at the bottom.
  7. HODD
    HODD Member
    115
    I shaped the air con unit to fit, the single din cage I modified and rivited in the kenwood cage.
  8. benr
    benr Member
    819
    yep, can modify the climatecontrol with something like a dremel.
    You can do as HODD has said or you can just get a double din cage but iirc they are about £60.
    Very neat install there HODD
  9. Ibzzzzz
    Ibzzzzz Member
    678
    That does look the ****!
  10. HODD
    HODD Member
    115
    For the best finish go for the factory stuff as you can't get it perfect modifiying the new shape a3 surround.
  11. <tuffty/>
    22,034
    4,304
    This is exactly what I was going to do with mine but went for a single din setup instead. I managed to swap my double din cage and climate control unit for a single din setup.
    I would have liked to have done the double din replacement and I have an A4 fascia that I started to mod to do it but not really that bothered about sat nav or video so decied to do the single din approach.
    Only downside is that I have a double din Symphony 2 unit I can't put back in when I eventually sell the car...
