Aftermarket Clutchs
Wai-Fan May 20, 2009
  1. Wai-Fan
    Wai-Fan Member
    530
    My clutch has started slipping, So I'm guessing I may need a new clutch sometime soon.
    Can anyone recommend any decent aftermarket clutchs for a 2.0 TDi?
    Thanks.
  2. Spin140
    Spin140 Well-Known Member
    2,196
    186
    Most guys go for a Sachs clutch, cost you about £800 fitted.
  3. Boydie
    Boydie S3 8V DSG VCDS Map User
    3,450
    588
    Yeah, Sachs do a clutch for 550euro then what ever you get to fit it!
    Apparently a good job - I will need one eventually!
  4. wolfbane1967
    wolfbane1967 Member
    237
    9
    Dont you need a new flywheel to?
    550 must be without flywheel
  5. Boydie
    3,450
    588
    You do not necessarily need a flywheel (afaik)
  6. Wai-Fan
    Wai-Fan Member
    530
    I've read quite a bit about the SACHS clutch, everyone seems to rate them highly. Are there any other options? I need a service and cambelt change in next few months so any more cheaper alternatives to the SACHS clutchs, but with similar performance?
    Also read about the flywheel, I see most people recommend to change the flywheel at the same time. If I don't change the flywheel, will there be any consequences??? e.g. flywheel falls off and makes the gearbox explode whilst knocking me out and crashing into a tree?
  7. devonmikeyboy
    devonmikeyboy As far from JBS as possible !
    1,245
    Sachs and Helix are the two main uprated clutch manufactures sold in the UK. Both are very good products with good backup but Sachs does seem to be squeezing Helix out of the market lately and developing better stronger clutches. If you want alternatives look at South Bend or Spec but with the **** exchange rate now they can work out quite dear unlike a last year.
  8. Boydie
    3,450
    588
    In my case, when I get round to changing the clutch, my flywheel will be changed also as its juddering - if yours isnt, then there is no need to change!
  9. Wai-Fan
    Wai-Fan Member
    530
    Ok so after reading around and all, I'm guessing I don't need to replace my flywheel unless there's a problem with it. So a SACHS clutch will be fine with the standard flywheel?
  10. Boydie
    3,450
    588
    Yes indeedy!
  11. devonmikeyboy
    1,245
    correct .
  12. smudge_don
    smudge_don Active Member
    2,944
    where is the best place to buy the Sachs clutch?
  13. Spin140
    2,196
    186
    any of your preferred local tuners should be able to help, as your down south either AMD, APS or Regal see who offers the best price fitted.
  14. devonmikeyboy
    1,245
