Aftermarket clock faces. Fitting...
Markb Dec 13, 2005
  1. Markb
    Markb Active Member
    2,139
    As subject has anyone ever fitted some aftermarket clock faces? Or does anyone know what sort of job they would be to fit?
    Cheers Mark.
  2. trevorb33
    trevorb33 Member
    35
    do you mean like the lockwood dials sort of thing, as my a3 came standard with white dials
  3. imported_Cali
    imported_Cali Guest
    Never done it on an Audi - used to do it on MKII Golfs a lot - bit findley you have to watch the platic clips the break easily.
    Good Luck
  4. Markb
    Markb Active Member
    2,139
    Yeah lockwood style ones.
    So how do you go about fitting them in general? How do you fit them over the needles? Do you have to remove them?
  5. HTC
    HTC Active Member
    3,428
    9
    Personally I thing fitting these faces will cheapen the look of your dash board. I thin kyour dials look fine as they are, but each to there own.
    If you have to fit them, it depends on whether they are a stick on or replacement faces.
    If you have to remove the needles the best way is to place a couple of credit cards (or normal card) either side of the needle and then lever the underside with a couple of dinner knives.
  6. madvw
    madvw Active Member
    2,489
    got to agree that replacement dial faces are horrible. They'll almost certainly not look like an OEM finish, and you'll forever risk your needles dropping off.
