Aftermarket adjustable front camber arms
Az Jun 19, 2013
  1. Az
    Az Hard slammed!
    1,035
    35
    Anyone know a cheap place to buy them which are actually based in the UK and would potentially have them in stock??
  2. Andie0
    Andie0 Member
    490
    13
    I dont think there is any mate unless you want to pay through teeth
  3. Az
    Az Hard slammed!
    1,035
    35
    The only ones I'm finding are the SPC (Eibach) ones, but they are only available in the states and work out to £250 plus £117 postage!!!!! Lol.
    Then there are some other real fancy looking ones (can't remember the make but there is no point in looking fancy if they're not even seen) and they work out about £100 more expensive than the SPC ones.
    They only charge that amount for them cos they know they can as very few manufactures make them! :(
  4. Mike.M
    Mike.M Well-Known Member
    2,510
    170
    Get someone who is a metal worker to fabricate them our of an original set........basic theory is to cut one in half, add a threaded pole to join, similar design but beefed up to a tie rod to adjust the toe in.
    I know a guy that is a master at this kind of thing on the south coast.....he is a good friend of mine
    coltechclassics.com
  5. Mike.M
    2,510
    170
  6. Az
    Az Hard slammed!
    1,035
    35
    Do you know what, I was thinking that its the same principle as the DIY rear adjustable oem arms that the 8L S3 boys do but on a slightly bigger scale. I think I'll have to be on contact with you mate about this, thanks a lot for the heads up! :)
  7. _adam_
    _adam_ Member
    47
    But you've got twin upper arms so you'd have to have both arms adjustable else you'd throw the toe out.
    Best solution surely would be an off set top mounting of some description or offset poly bushes in the the control arms
  8. Mike.M
    2,510
    170
    Yes you would have to have four made up.
  9. Az
    Az Hard slammed!
    1,035
    35
    Which explains why the aftermarket ones are so expensive then. Mind you, I guess they work out to about £80 an arm.
