After-market DRLs
Neil C Jul 9, 2011
  1. Neil C
    Neil C Active Member Team Brill Red Audi A3 S-line owners group TDi Manual
    273
    175
    43
    Apologies if this has been discussed before, but I had a quick look through previous posts and couldn't find anything.
    For a few weeks now, I have been debating whether to purchase the following after-market fog grille mounted DRLs for my 54-plate Sportback.
    DAYTIME DRIVING LIGHT IN FOG GRILLES FOR AUDI A3 8P >08 on eBay (end time 20-Jul-11 18:29:53 BST)
    With a pending divorce, money isn't exactly flush at the moment, but I feel the need to treat myself, only I can't afford to be buying a dud.
    Your thoughts and opinions would be greatly appreciated
    Neil
  2. mike foster
    3,967
    They will be ok and will look the part !
    However, if you're any good at car DIY you could go to Halfords and buy a set of 'Ring' daytime running lights for about £60 and fit them yourself. You will need to adapt the grilles slightly with a Dremel but they will look ok when finished.
    Good luck !
  3. evilbane
    evilbane Member VCDS Map User
    129
  4. mike foster
    3,967
  5. mrpeng
    mrpeng 2.0T Quattro
    78
  6. mike foster
    3,967
    It is actually these that I am referring to. They are much narrower and fit the grilles better and are very bright (in my opinion ! )
    Halfords | Ring 8 x LED Daytime Running Lights
    They have a proper fixing bracket so ignore the double sided tape bit !!!
  7. Rhyso
    Rhyso Well-Known Member
    1,536
    320
    Grab a copy of VAGCOM and have a look to see if you can enable your fogs as DRL's. Being an early car you might not be able to but I enabled it on a 54 plate GTI yesterday. Best thing is you can then use the fogs as fog lights like before :)
  8. mike foster
    3,967
    Last I heard it was illegal to run with foglights only if the weather was ok !! ( in the UK that is )
    Just bought a set of those in my post #6 and they are very neat and very bright. Will post pics when I have fitted them which, unfortunately, won't be this weekend.
  9. glasgowal
    glasgowal Member
    116
    I think they'd look good. I'd get them if i wasn't gona be making space for my FMIC D:
  10. Rhyso
    1,536
    320
    I've adjusted the brightness to about 25% and they look no brighter than new cars with DRLS
  11. Lings
    Lings Active Member
    2,059
    31
    You will still get a fine for running fogs as drl .Make the coppers day by doing that method even with lower brightness
    Euro car parts had some good ones on offer iirc there Philips .theres also a 30% Euro car parts code on here some place do a search
  12. Rhyso
    1,536
    320
    What about new cars that use fogs as cornering lights?? Surely that's just as annoying?? Not to mention it looks like a load of news cars has a major fault lol
    I'll take the risk and continue to run them as they are. If I get fined then so be it but it would be nice to see other people pulled over who run their fogs at full brightness when its perfectly clear.........
    EDIT - do you have a link to the information where it says you will get a fine? I've had a look myself but I cannot find anything.
  13. Yaks
    Yaks Member
    181
    Personally don't like aftermarket DRLs that fit to the car in a different place to OEM ones.
    Think it looks a bit "tacky" myself, but understand that if you like it then go for it.
  14. Lings
    Lings Active Member
    2,059
    31
    When you get pulled they will gie you the info mate .Had a few pulls using fogs at NIGHT
  15. danb986
    danb986 In awe of VCDS Team Daytona
    525
    What about the new Passats and Skodas that have what looks like their front fogs as DRL's? I don't mean the LED ones, it's the round ones that look exactly like front fogs. I've seen loads of these about now and I'm wondering how many of these cars are getting pulled over by Police that think they have fogs on?
  16. mike foster
    3,967
    That's a very good point !
    Perhaps someone on the forum knows a traffic policeman who could advise the current UK position ?
    We could all benefit from the info. !
  17. TheKing
    TheKing New Member
    19
  18. A3LMM
    A3LMM New Member
  19. TM
    TM S-line SB
    144
  20. TheKing
    TheKing New Member
    19
    Problem with them is your going to have to get into the headlight unit to mount them.
  21. audicruiser
    audicruiser Audi Heaven
    1,865
    Use of a fog light when the visibility is greater than 100m is deemed illegal (if the brightness is the full 55w 100%)
    The DRL setting that Rhyso has set on his car is VAG legit as the brightness is set to 25% of the light capacity and turns off on that side when the indicator is used.
    Don't get hung up on what the light is called. Pre facelift S3 and B7 RS4 ran their high beam units as drl but at a lower brightness from the factory. All legal....
    The current Passat uses the lower lights in the grills as both DRL and Fog lights....
  22. TM
    TM S-line SB
    144
    true, bumper off job no doubt, and then into the headlight unit.
  23. TheKing
    TheKing New Member
    19
    The only problem with that is the unit is sealed so it quite tricky getting into it if my old car was anything to go by.
    If your worried about those ring drls looking like those led strips on ebay i wouldn't be they're completly different the brightness is the key, I asked mike foster about this and he gave me great advice and direccted me to halfords where you can test them and see the brightness that's the only reason why i mounted them on my motor.
  24. danb986
    525
    I've activated mine at 50% brightness. They turn off when I put my sidelights on, but they're not affected by the indicators. I was followed by a 60 plate Skoda Superb this morning with fog lamp type DRL's and his both stayed illuminated when he was indicating too. I thought the option to do this in the coding was for cars with LED DRL's in the headlights as they could mask the function of the indicators.
    Rhyso, do yours do this? I followed your guide for the coding but mine don't go off on the side I indicate.
  25. Rhyso
    1,536
    320
    Mine remain on when I indicate although there is the option within the long coder which will turn the DRL off when you indicate. Can't remember the exact byte but it is there. I'll try and grab a screen shot later :)
  26. FranA3
    FranA3 FMDETAILING Site Sponsor Regional Rep Gold Supporter Team Brill Red Audi A3
    7,264
    363
    not a fan of aftermarket drl's as ive seen allsorts of cars with them now and i think they look tacky ive got drl's on mine they are set as my main headlights but was thinking about getting them changed to my fogs as loads of new cars have them as drl's
  27. danb986
    525
    I'm sure I've seen that option too, but I thought it was just for the LED models. It might look a bit odd now I think about it. The indicators and fogs aren't exactly next to each other.
  28. Ash187
    7,519
    756
    Get original Bi-xenons with DRLs... its OEM and looks mean!
    and you can always fit in canbus LED bulbs into it if you want.
  29. danb986
    525
    I'd love a set of genuine Bi-Xenons, but they're not cheap and I'm not supposed to be spending much on this car (according to the wife!). :whip:
  30. Ash187
    7,519
    756
    HAHAHA... just dont tell her... she wont really notice! :p
    yes they do cost.. if you have a £500 budget you can usually get them in all fitted... but so much worth it!
  31. Rhyso
    1,536
    320
    Yeah initially I enabled the option but when I saw it in action I wasn't overjoyed; it looks like a new car which uses fogs as cornering lights, broken! lol
  32. Neil C
    273
    175
    43
    Now you've started to talk about VAG coding, etc, did I read once that you can have the coding altered so that your rear fog lights ( sportback ) come on, at a reduced brightness, with your brake lights ?
  33. mike foster
    3,967
    Not that I'm aware of. You can't on my 2006 sportback.
    You can code it to make the hazard flashers come on under very heavy braking if you want. I have done that but fortunately have never tested it !!!!
  34. Neil C
    273
    175
    43
    I'm sure that I didn't imagine it, but it would've been possibly 3 - 4 years ago when I read about it.
    It's not the sort of question that your local Audi dealer likes to answer either. Can't think why ! lol
  35. mike foster
    3,967
    Well I have genuine VCDS and have extensively explored all possibilities of lighting alternatives and I can assure you that, with my model, that alternative is not available.
    Had it been then I would probably have selected it !!
    audicruiser likes this.
  36. Neil C
    273
    175
    43
    I know, it sounds awesome doesn't it ?
  37. Rhyso
    1,536
    320
    I think both Neil and Mike have the early versions of the Central Electronics module meaning half the options are unavailable to you. I'm looking at a 56 plate A3 this weekend so will scroll through the options and see what can and can't be coded :thumbsup:
  38. mike foster
    3,967
    Cheers Rhyso - for reference my Central Electronics module is 8P0 907 279 F (23 Byte version )
    My coding is 00062736
  39. Rhyso
    1,536
    320
    Cool; I'll report back on the weekend :)
  40. NCRAW
    NCRAW Member
    230
    Anyone knows if u can switch from bulbs drl to led drl on the s3 8p via vcds? I heard it's doable on the q7 pre face lift (as the post face lift are led)
