After market Double Din Head Unit
silversurfer Feb 22, 2009
  1. silversurfer
    silversurfer Member
    223
    Hi,
    I'm after some help.. Does anybody know my double din kenwood head unit would fit with the below climate control unit..?
    I presume the Climate unit moves to the bottom and the head unit then fits in above..? Or do I need a different Climate unit :(
    Neil
  2. Issac Hunt
    1,162
    You need a different climate unit or you need to trim the edges of your current unit.
  3. jwhat
    jwhat Member VCDS Map User
    541
  4. BahnStormer77
    BahnStormer77 BahnStormer
    2,754
    53
    wot them lot said :icon_thumright:
    You'll need a new cage and then either replace the climate control unit with the narrow version or take it out, trim down the edges (apparently they're actually marked out where to cut) and then as you had mentioned: reseat it lower in the dash.
  5. silversurfer
    silversurfer Member
    223
    Nice one.. :happy: Thank you..
  6. silversurfer
    silversurfer Member
    223
    Does anybody know the audi part numbers of the cage I'd need.?
    Thanks Neil
  7. technics100
    technics100 Member
    848
    24
  8. silversurfer
    silversurfer Member
    223
    Is it difficult to replace the cage..? And from the look of the above Ebay link the same part is used for the B6 and B7 A4's. Is that right..?
  9. technics100
    technics100 Member
    848
    24
  10. 1wheelonly
    1wheelonly cabriolet VCDS Map User
    2,376
    108
    did mine myself, fairly straight forward, but not a two minute job, allow an hour or two
  11. PetrolDave
    PetrolDave Well-Known Member
    1,559
    85
    Yes, the B7 was just a facelift of the B6 not a completely new model.
  12. BahnStormer77
    2,754
    53
    that's right... B6 and B7 parts often interchangable.... especially in the dash.
    My B6 has the "MMI" version of the RNS-E.... not that I know what the MMI version looks like - might just be the splash screen, but a friend reckons it's very different from what's in his 2003 B6 ;D
  13. PetrolDave
    1,559
    85
    Your friend doesn't have an RNS-E in his 2003 B6 - he has it's predecessor, the CD based RNS-D (like I had in my 2003 B6 S4). That has a non-motorised screen, doesn't take SD cards and has two large knobs to control it instead of the one that the RNS-E has. They are very different systems.
    The RNS-E has absolutely nothing in common with the MMI in the A5/A6/A8/Q7 - it makes me really angry that some idiot at Audi decided to make the RNS-E show "MMI" on start-up. It doesn't share ANY common parts, and it doesn't use the same map DVDs. I've seen dozens of people spend £200+ on an MMI DVD because their RNS-E says "MMI" - only to find the DVD they have bought is totally useless to them.
  14. BahnStormer77
    2,754
    53
    Thanks for clearing that up, Dave.... makes a lot more sense now.... I thought somebody had just done a dodgy hack-job on my RNS-E to give it the MMI splash screen!!
