AFR Gauge (1.8T AMK)
Yohan87 Aug 15, 2012
  1. Yohan87
    Yohan87 Guest
    Afternoon,
    Just wondered whose running an AFR gauge and what make if they are?
    Heard good things about the AEM Wideband 02 UEGO Gauge. AEM Wideband O2 UEGO Gauge - Monitor Air/Fuel Ratio with the Digital 30-4100 - Wideband O2 UEGO, Water/Methanol, Stand Alone Engine Management, Piggyback F/IC, Tru Boost Controller, Gauges, Automotive Performance Electronics
    The engine it would be going on is a 1.8T AMK (S3).
    I already have gauges for Oil Pressure, Oil Temp, Boost, and Voltage, but I've always wondered if I should have AFR as well.
    Does it just connect in where my existing lambda probe (already mapped out) goes?
    Is it a case of connecting the lambda probe up to the gauge and away you go or is there a separate controller required?
  2. <tuffty/>
    21,572
    4,047
    Have used AEM and VEMs gauges for AFR in the past on customer cars... VEMs has an EGT probe too which is useful...
    How do you mean your lambda is mapped out? I assume you mean the post CAT one?
    Normally they should go near the turbo outlet so normally weld a boss next to or close to the existing pre-cat lambda
  3. Yohan87
    Yohan87 Guest
    An EGT probe would be useful as well, can they both be shown on the same VEM gauge? Any links to said gauge?
    Yes that's what I meant, I'm running a de-cat and so the post CAT lambda sensor has been mapped out.
  4. <tuffty/>
    21,572
    4,047
  5. Yohan87
    Yohan87 Guest
    Cheers tuffty.
  6. jay1601
    jay1601 Well-Known Member
    1,344
    73
    i got the AEM UEGO.
    i've got the 3"DP/de cat. as mine has the AGU limp only have 1 lambda so i had a spare hole for it.
    just a case of just the sensor in and run the wiring up to the gauge. and then a live feed and earth wire
    nice easy job
  7. badger5
    9,542
    2,022
    add a second boss close the the main lambda for accurate readings... too far away and it will be more sluggish responding
    VEMs egt is an option, and is handy for 2 gauges in one
  8. Yohan87
    Yohan87 Guest
    Thanks guys.
    Had a chat with Nick@R-Tech last night and he offered another suggestion - Innovate Motorsports MTS Modular Tuning System
  9. <tuffty/>
    21,572
    4,047
    Humm... I know Bill has seen issues with the Innovate controllers...
  10. Yohan87
    Yohan87 Guest
    I see.
    This is the idea behind my original post, get all these experiences together :)
  11. badger5
    9,542
    2,022
    Innovate LC wideband and their having to remove to do air calibrations put me off... that and the poxy thing was unreliable..
    Used AEM been very good, VEMs also been ok.. and dual gauge has its appeal
  12. Yohan87
    Yohan87 Guest
    Bill can you supply the AEM afr kits? If so can you PM me an all in price please?
  13. badger5
    9,542
    2,022
    replied
  14. S3 Paul
    S3 Paul Well-Known Member Regional Rep
    2,825
    107
    I have an innovate MX or something like in my S3...
    It realy doesnt like it when the injectors shut off on over run.
    It forever throws an error code . on track or fast driving its fine. just eco driving it throws up errors.
    I also have an LC1 in my mk2 which is fine. Wierd.
  15. badger5
    9,542
    2,022
    your glitchs with innovate match my dislike of them
  16. Yohan87
    Yohan87 Guest
    Sounds like AEM UEGO is the way to go :)
