afn tdi boost leak i think please help
pirate Jul 24, 2011
  1. pirate
    pirate Member
    54
    got boost in low gears but under load and up hill boost guage flapping and no pull
    can hear turbo tho
    where should i check as i have tried to find it but cant
    my friend said when he first heard the car it has a boost leek
    today was the first time on the motorway nothing there in 5th 4th
    can hear the filter sucking but just dosnt have any go
    struggles to do over 60 and have to drop it up hill
    any help verry apreciated thanks dan
  2. Bradderz_1988
    3,986
    261
    Egr valve perhaps ??
  3. tjg04
    tjg04 New Member
    Just check all of the hoses from turbo to inlet manifold. Likely to be one of the larger diameter rubber hoses going to-from the intercooler, or the 's' shaped one from the turbo to the metal pipe that runs with the bumper. Sounds like a split that only opens up at higher boost pressures, so you might have to take each pipe out and properly examine it. Failing that replace all of the jubliee clips as one of these could be dodgy. I had a problem with mine going into limp mode becuase of a boost leak that I couldn't find. I made a crappy low pressure boost leak tester using two jubliee clips, an old bicycle inner tube and my bike pump. Won't find high pressure only leaks, but found a pinhole leak in my MAP sensor pipe that was causing my issue.
  4. pirate
    pirate Member
    54
    many thanks and i have blanked the egr will be stripping all pipes tomorro to check for leaks and replacing any im unsure about i have blanked the egr but there is a slight leak of oil form the egr plate nearest the turbo but there is a gasket in there and its rely rigged up , also im unsure if the boost guage t piece is on the correct hose under the bonnet can sum one advise which hose it should be in thanks dan
  5. pirate
    pirate Member
    54
    like u said yep just sometimes it goes lame when car gets warm mostly or is given a bit of stick but sometimes it feels good and like its fully boosting very wierd
