Hi, I'm working through "the list" in an attempt to cure limp mode on my afn, I've had a local garage check with vag com and all it picked up was 00575. so far i've blanked off the egr, and unplugged the maf to rule that out ( had to pull over and plug it back in after a couple of miles, as it was really flat!),I have just swapped the vacuum valve (n18?)that the egr is plugged into ( fixed underneath the hard plastic inlet pipe toward the rear of the engine) with the vacuum valve(n75?) that the turbo is plugged into( fixed behind the rad at the front of the engine) i wont know till i drive home tonight to see if its any different, is it ok to leave them swapped, are they the same valve?
i know it has probably been covered in other threads, but i just want peace of mind, as i'm not really that knowledgable on engines ( i don't even change my own oil !!)
thanks
Neal
thanks
Neal
