AFN engine flywheel
shaz8389 Aug 16, 2012
  1. shaz8389
    shaz8389 Member
    43
    Pretty quick question,
    Dual or single mass flywheel?
  2. AR-rkon
    AR-rkon Mod back in a "B" Staff Member Moderator Regional Rep Team V6 Team Silver Audi A6 Audi A4 Audi Avant Owner Group
    1,912
    164
    Dual
    there has not been a 1.9tdi with a single in an a4, only single i know of was the audi 80 tdi 1Z
  3. shaz8389
    shaz8389 Member
    43
    Car judders a wee bit if rolling forward on the bite but is fine the rest of the time. Think I may be on borrowed time!
    Can I convert it to single mass or is it an expensive and time consuming headache?
  4. AR-rkon
    1,912
    164
    think the 1Z flywheel will fit, and you can use the 1Z clutch, IIRC its bolt for bolt.
  5. shaz8389
    shaz8389 Member
    43
    As in the Golf/Passat engine?
    If that's the case then can you do the Golf thing and do G60 flywheel/VR6 clutch combo that upgrades Golfs? Looked at conversion kits and it's north of 300 quid just for the flywheel, car only cost me 500 quid!
  6. adamss24
    adamss24 Well-Known Member
    4,559
    394
    Early passat/audi a4 with the AHU 90 Bhp engine had single mass flywheel up to 1997, then DMF onwards...
  7. adamss24
    4,559
    394
    You cannot use golf clutch and flywheel as they are different designs. As pointed 1Z solid flywheel and s2 clutch bolts on and let's you use a 240mm clutch- all bolt on. Alternately you can get SM kits from Valeo but they are not renowned for reliability + don't take power upgrades too well. If you get on Darkside Developments website then you could check their new Southbend Silent clutches and single mass flywheel kits, worth every penny !
