AFN ECU and chipping
ScottD3 Feb 19, 2013
  1. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 Team Akoya saloon TDi
    15,164
    1,123
    Toying with the idea of getting my ECU chipped but since its old and can't be done via the ODB port, I've been thinking about getting one off ebay.
    Send that away to get chipped, swap it over with mine and then sell mine on.
    I guess it works in theory but is there any difference between newer or older AFN ECUs?
    Would it be advisable to get a newer 110 AFN ECU over a older or same age as what I'm running at the moment?
    Thoughts?
  2. birch1983
    birch1983 Member
    43
    I have a similar problem with mine. 1.8t AEB. Ecu unable to communicate via ODB port. I have been told I could use an AGU ecu. Not quite sure if this would work, and then have that re-mapped. Could you not do anything similar. Don't know much about the diesels I'm afraid and any input on my predicament would also be appreciated.
  3. adamss24
    adamss24 Well-Known Member
    4,584
    407
    What year is your b5 ? There are 3 types of ECU fitted on the b5, 1 is a EDC15 and is writeable trough the OBD- only fitted to very late facelifted b5 with AFN/AHU/AHH and AVG engines. the other two are a MSA15 type ECU's and will require old chips removal and new sockets to be soldered to the PCB.
  4. aragorn
    18,579
    868
    Are the ECU's interchangable?
    IE can he find an EDC15 and fit it to his car? Or are the IP's different on the EDC versions?
  5. ScottD3
    15,164
    1,123
    So no chance of it having a EDC15 but like Aragorn said.
    Can I fit one?
    EDIT:=- Would I need a ECU from a Auto since mine is an Auto?
  6. AR-rkon
    AR-rkon Mod back in a "B" Staff Member Moderator Regional Rep Team V6 Team Silver Audi A6 Audi A4 Audi Avant Owner Group
    1,913
    166
    Autobox ECU is separate IIRC. should just need coding with VCDS. so could use any.
  7. ScottD3
    15,164
    1,123
    That's what I'm hoping and going by what Adamss said, if I can fit a EDC15 ECU to my car. I'd be laughing..........Hopefully.
  8. aragorn
    18,579
    868
    Petrol ECU's cant be "coded" for an Autobox. The actual program code the ECU runs is different. Not sure if diesels are the same, i believe some later diesel ECU's are switchable between manual and auto, but not sure if that applies here.
  9. stuartk
    stuartk New Member
    10
    check out audiparts4you on ebay he will sort you
  10. adamss24
    4,584
    407
    I have a chipped ecu done by superchips, it will work on your and it does not need codding. I could part with it for the right money...
  11. ScottD3
    15,164
    1,123
    Hmmm, could be interested.
  12. stuartk
    stuartk New Member
    10
    what gains did it give you what you looking for it
