Aero Rear wiper for an S3... That fits!!
fdussud Jun 29, 2006
  1. fdussud
    fdussud Member
    40
    I thought I would just mention this incase it has not been done yet.
    I bought some aero front wipers for my S3 from VAG-parts and was informed that they did not have a rear aero wiper kit for the S3, only the A3. I was told this was due to the spoiler on the S3, causing the A3 wiper to hit it. The guy at VAG-parts said that some people end up cutting the A3 wiper to help it fit.
    Luckily, on a french S3 website, they listed part numbers for a setup that will fit the S3, and yes it fits, however just to make you aware, it is a little shorter than the stock wiper, about 1cm, if that.
    6Q6 955 425A is the wiper
    6Q6 955 435B is the cap to cover the nut
    6Q6 955 707A is the wiper arm.
    Hope this helps. I will try to post some pics in the gallery.
  2. madvw
    madvw Active Member
    2,489
    most people use a rear polo arm, with a rear touran blade - that seems to just fit too.
    EDIT: 6Q6 955 707A is the part number for a rear polo aero blade. try using a touran one, it's just that little bit longer and doesn't look as daft.
  3. dickys3
    2,954
    Agreed. This is what I had on mine and it worked well.
  4. jojo
    28,907
    3,563
    I got mine of MarkB for a fiver, and it fits and works, not sure what parts they are though...
  5. PaulRS3
    PaulRS3 Well-Known Member
    1,218
    150
    I ues a polo arm and touran wiper.
    bought from vagparts funnily enough.
  6. fingermouse
    fingermouse thats me
    4,003
    112
    i also got my set up from vag parts all fit ok
  7. rgb8888
    rgb8888 New Member
    24
    "Aero Wiper" Sounds interesting - are these changed for visual impact?
    If so can anyone include a quick pic so I can see what it looks like
    RGB
  8. PaulRS3
    1,218
    150
  9. The Slug
    The Slug Active Member
    1,869
    I had the A3 Aerowiper kit from Vagparts and rear fits well, in fact i think the blade is shorter than the OEM one anyway, so shouldnt catch anything on S3.
  10. dickys3
    2,954
    You probably had the polo wiper blade then Rich as this is shorter.
  11. The Slug
    1,869
    Think your right Rich, in which case buying the A3 kit would be fine
  12. leecs3
    leecs3 thinking about stuff
    604
    whats the cost of front and rear aero wipers?
  13. madvw
    madvw Active Member
    2,489
    front wipers (arm + blades) usually around £80, rear arm + wiper usually £20.
  14. Daz A3 TDI 130
    Daz A3 TDI 130 Warp factor 10
    What makes these blades so special?
  15. gek
    gek New Member
    They look nice and make your car go faster!
  16. madvw
    madvw Active Member
    2,489
  17. solihul
    solihul Member
    60
    Nice touch
