  1. floyd 1.8 turbo
    floyd 1.8 turbo Mirror, Signal, Outmanoeuvre
    632
    Right i'm having a bit of a nightmare trying to get the right ones, mine measure up at 520mm. Both the same size. All the bosch twinblades are different sizes from what i can see.
    Any help would be very welcome!!
  2. Purple Princess
    Purple Princess Moderator Moderator
    1,044
    The right ones would be off a B 5.5 Passat full kit around £90 new. If you get on the bay and email everyone breaking one, you may get lucky :)
    Good luck
    Stacey
  3. floyd 1.8 turbo
    632
    I've already got aero blades, need new ones though and heard good things about the bosch twins. Only need the blades themselves
  4. aragorn
    18,601
    870
    afaik B5's have one slightly longer blade and one slightly shorter one.
    From memory, the drivers is 21" and passenger is 20".
    Whether this changes on the aero blades i'm not sure, but surely if you just buy the correct blades for the arms your using it'll be fine?
  5. floyd 1.8 turbo
    632
    Correct as in size?
  6. Broken Byzan
    13,237
    466
    yes, as in size. IIRC i bought my last set from hellfrauds.
