Aerial amplifier pc5-52
vwgtiking Aug 21, 2013
  1. vwgtiking
    vwgtiking Active Member
    1,027
    I have an aerial amplifier pc5-52. It also has a blue wire coming from it. Is this connected to remote or the ignition wire I will wire in?
  2. Emmo
    Emmo Member
    223
    12
    You can connect to the remote lead from your head unit if your not using it to run an amp otherwise connect it to the power antenna cable from your head unit, usually a blue and white striped wire.
  3. vwgtiking
    1,027
    The remote will power sub as well. Is it too much to power both?
  4. Emmo
    Emmo Member
    223
    12
    Wire it to the power antenna wire then.
  5. vwgtiking
    1,027
    The power antenna is also the remote it's the same wire.
  6. Emmo
    Emmo Member
    223
    12
    Most head units have separate wires for this. If you only have the one just wire the amp and antenna and it should be ok to power up both.
  7. vwgtiking
    1,027
    Connected to ignition live in the end.
