AEB oil pump
les riva Feb 21, 2007
  1. les riva
    les riva New Member
    Changing oil pump on a 98 1.8T A6. Engine code AEB. What a bitch of a job getting the sump off. Does the subframe have to droped to remove the sump and the oil pump? Can anybody help.:faint:
  2. Rev-head
    Rev-head Active Member
    2,987
    Hello and welcome and post in the A3 section regarding pump might get some better replies
  3. TDI-line
    TDI-line Uber Post Whore Team Floret Silver quattro Audi A3 Black Edition TDi
    9,710
    1,734
    Hello and welcome.
  4. les riva
    les riva New Member
    Ok. Hi anybody thinking about changing a oil pump on a AEB 1.8T, in an 98 A6.
    Just finish the job. Hope this helps. You do have to drop the sub frame. Tried undoing the engine mounts and lifting the engine up, but is just doesn’t give you the room needed to slide the sump out and will not give you the room to extract the oil pump. Plus it is so much easier, with the sub frame hanging, to get at all the bolts holding the sump on. This, once the sump is removed will also give you the room to pull out the oil pump and its shaft.
    Now the reason I’m changing the pump. Had the oil warning light come on, while slowing down from motorway speeds, when hot. Fine at 70+ and at tick over, but not at 1200 to 2000rpm. Oil warning light came on. Thought it was the typical oil strainer choked up, but no. It was the pressure relieve valve. It was heavily scored and sticking. After the oil light had gone out the engine sounded very tappetty! If you stopped the engine and started it after 30 seconds, the engine was quiet again. Maybe the relieve valve had freed its self with no pressure in the system? Hope this helps and may give some indication to oil pump problems!
  5. L1 HCS
    L1 HCS Active Member
    4,600
    Hello & :sign_welcome: to the site.
  6. SamDude
    SamDude Active Member
    2,102
    Howdy!
    Welcome'n'all that!
  7. Randles
    Randles Member
    96
    Hi and :sign_welcome:
  8. Sinny71
    Sinny71 S55 LKS
    779
    :sign_welcome: n all that..!!
  9. Broken Byzan
    13,237
    465
    Welcome, and thanks for the tips, its things like that,that make this the fantastic resource it is
  10. Randles
    Randles Member
    96
    :sign_welcome:
    Enjoy your stay:icon_thumright:
