AEB oil capacity
voteforpedro Jun 7, 2010
  1. voteforpedro
    voteforpedro Member
    632
    Can someone please confirm the engine oil capacity of an AEB before I attempt my oil change. I put nearly 4.5 litres in last time and was told I overfilled it.
  2. voteforpedro
    voteforpedro Member
    632
    No one knows how much oil to put in their car? o_O
  3. Broken Byzan
    13,237
    465
    3.5 litres on a std small filter, if you use the larger filter you get an additional half litre.
  4. aragorn
    18,443
    847
    And stick some oil in the fresh filter before you put it on, it soaks it up like a sponge and it takes the strain off the engine a little when its first started!
  5. voteforpedro
    voteforpedro Member
    632
    Do you recommend changing the filter each oil change? Only driven it 2k miles or so since last filter and oil change.
  6. Broken Byzan
    13,237
    465
    TBH for £3 or whatever its hardly a great saving to not do it.
  7. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    its a bit like putting clean trousers over soiled underpants not to do it at the same time as the oil........
