AEB inlet manifold on a BAM
S321BAM Jul 21, 2013
  1. S321BAM
    S321BAM I lost the rod lottery
    124
    24
    Evening guys
    Quick question......im going to be fabricating my own plenum using a AEB manifold as a donor. Reasons because I have an AGU head to go on. Are the injector ports the same as a BAM or will they need modifying?
    Cheers, Chris
  2. <tuffty/>
    20,900
    3,710
    The injectors need modding depending on what ones you are using as the injector bungs on the AEB are smaller and BAM injectors have a shoulder to stop them being pushed too far in on small port inlets... this shoulder needs to be carefully filed to allow the injector to sit in the bung...
    You may also need to space the fuel rail depending on what injectors you use too...
    Mine with 630cc dekas..
    http://www.audi-sport.net/vb/a3-s3-...9-my-minor-modding-thread-41.html#post1645461
    ...and now with 550cc Bosch...
    http://www.audi-sport.net/vb/a3-s3-...9-my-minor-modding-thread-48.html#post1797926
  3. S321BAM
    124
    24
    Thanx Tuffty
  4. IrishDave
    IrishDave Active Member
    682
    45
    @ Tuffty.
    I will be using bosch 550 on my build also. Using a standard bam inlet mani. Will I also need spacers for these and if so where do I get them.
    Thanks.
  5. <tuffty/>
    20,900
    3,710
    Bill runs this setup on the Lupo... pretty sure we didn't use spacers on that... I'll try and remember to ask Bill in the week unless he sees this first...
    IrishDave likes this.
  6. badger5
    9,404
    1,944
    on stock mani, bosch 550's dont need spacers no
  7. IrishDave
    682
    45
    ^^ Thanks
  8. S321BAM
    124
    24
    Can anyone tell what the sensor is on the bam inlet by the dip stick please?
  9. <tuffty/>
    20,900
    3,710
    EGT probe if you mean the one underneath or air temp sensor if you mean the one by the throttle body
  10. S321BAM
    124
    24
    Not the sensor by throttle body. Take it the position of the probe hasn't got be exact?
  11. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    You mean the intake air temp sensor.... and no it doesnt have to be exact obv in the flow
  12. s3dave
    10,110
    736
    On a side note AGU runners need the fixing for the inj rail cutting down about 12mm for 550s or by the stupidly priced spacers that extend the injector
  13. badger5
    9,404
    1,944
    stupid priced unspacers?
    you think?
  14. s3dave
    10,110
    736
    When i was looking at £60,, so yes very stupid, when all you have to do is cut 12mm off the mani mounting points
  15. S321BAM
    124
    24
    [​IMG]<br><br >[​IMG]<br><br>[​IMG]<br><br>[​IMG]<br><br>[​IMG]<br><br>[​IMG]<br><br>[​IMG]
    Sam_, s3dave, superkarl and 1 other person like this.
  16. S321BAM
    124
    24
    ^^^^ so ive made a start on the manifold. thought i'd share some photos as it progresses ^^^^^
    <tuffty/> likes this.
  17. badger5
    9,404
    1,944
    £60??
    wtf price did you find them??
  18. badger5
    9,404
    1,944
    Where did you get the radius stacks>? they look lovely
  19. S321BAM
    124
    24
    Had the turner at work make them from a sketch i made and then got one of the millers to machine the slot in to match up with the manifold ports
    ReDBull likes this.
  20. Dani_B19
    9,112
    346
    S321bam, you making anymore of these? What plenum you using?
    s3dave likes this.
  21. Scullies
    Scullies Well-Known Member
    1,543
    657
    make more and sell them, they look awesome!!!!
  22. S321BAM
    124
    24
    Just making this for myself at the moment, will take notes of dimensions etc for future reference if needed. plenum wise will be fabricating it all from scratch, want it slightly bigger than std and look oem. Going to be running a k04 for a while yet and not sure how a larger plenum will effect everything
  23. badger5
    9,404
    1,944
    dont fancy trying one of these plenums?
    Scullies likes this.
  24. S321BAM
    124
    24
    How much are they? planned on doing it all myself to keep cost down to nothing, as i was given the donor manifold and using off cuts from work. How would a plenum that size effect a k04?
  25. superkarl
    superkarl MAN OF STEEL
    9,405
    2,378
    I KNEW id see dani in here as i scrolled down! Lol. You'd be interested in aids if it came in something shiny!
    Nice work, welding looks very professional! I dunno what i prefer more, your precision, or scullies colouring in! Lol
    Gops and S321BAM like this.
  26. Scullies
    1,543
    657
    instant 500hp :eyebrows:
    on the porn o meter :)
    superkarl likes this.
  27. Scullies
    1,543
    657
    Those machined babies are way nicer but I'm sure they must be pricey as it would take some time to machine them.
    My colouring in numbers are more for the DIY enthusiast.
  28. S321BAM
    124
    24
    TBH having a semi CNC lathe and mill makes it easy work.
  29. Chlippo
    Chlippo Member
    679
    15
    Looking great! good work
  30. Dani_B19
    9,112
    346
    Lmfao, what's with all this about me been attracted to shiney things like? Dave set it off and for some reason its seemed to have bloody stuck haha.
    s3dave likes this.
  31. superkarl
    9,405
    2,378
    you are a magpie
  32. s3dave
    10,110
    736
  33. Dani_B19
    9,112
    346
    Meh, all hear say.
  34. badger5
    9,404
    1,944
    more over the largeport runners will loose you low end torque but add some up top >5krpm, BUT on std k04 thats not where its at its best flow wise as its petering off up there
  35. badger5
    9,404
    1,944
    Its low £200ish after tax and shipping approx.
    + throttle body adaptor plate required
  36. S321BAM
    124
    24
    OUCH! for a bit of cast ali......i'll stick with the original plan, can always mod it at a later date to fit a larger plenum like that
  37. badger5
    9,404
    1,944
    lol
    predictable response
    excessive manufacturing.. USA + shipping + duty +vat it all adds up by the time they land here
  38. S321BAM
    124
    24
    Have had casts made in the past to make formula ford uprights that you can't get hold of anymore so might look into this
  39. S321BAM
    124
    24
    managed to get a bit done this week.....
    Sam_ and gordon c like this.
  40. Sam_
    Sam_ Down under
    3,035
    480
    Looks good - would probably have been better if you could have tapered it more to the furthest cylinder from the throttle body but I'm sure it'll be an improvement.
    There's a company selling billet injector cups on vw vortex which would complete this nicely :)
