AEB Head - stk cams or S3 cams
Scullies Sep 14, 2012
  1. Scullies
    Scullies Well-Known Member
    1,543
    658
    Hi Guys
    As above, should I use the stock AEB cams or should I transfer the cams from my S3. This is temporary as the courier has lost my cat intake cam :(
    Are there any differences between camshafts on the 1.8t 20v heads?
  2. Westy
    Westy Well-Known Member
    17,443
    1,105
    I transferred my S3 cams into the AEB head only because I knew the history of my cams over the AEB ones. Apart from that there should be no difference.
    You will also need to transfer over your VVT unit if you have one as AEB heads don't.
  3. <tuffty/>
    21,885
    4,204
    You can't use the pully from an AEB head as the inline setup is different... you will need the cam position wheel from the S3 if yours is an AMK/BAM as VVT is 4 window rather than non VVT 2 window
  4. Scullies
    1,543
    658
    Thanks for the wise words guys :icon_thumright:
  5. Dan s3 audi
    Dan s3 audi Member
    164
    i changed my apy head for a aeb head, asked audi and they checked the part numbers out and both the cam are identical part numbers. the only part i did change was the cam pully and the sensor cap thing.
  6. Scullies
    1,543
    658
    So I finally got some cat cams to go with the AEB head.
    I remember Tuffy mentioned that I will need to use the VVT from my S3 engine. What would happen if I didnt use the VVT? Is it possible or will it cause issues with the ECU ?
  7. Andrew@A.L.D
    3,879
    617
    If you wanted you can code out the VVT but i don't see the point if you have then keep.
    You can run without the VVT but a error code would come up
  8. Scullies
    1,543
    658
    the aeb head that I got came with a brand new cam chain tensioner and thought it might be better to use it rather than the used VVT,
    but I dont want to have error codes.
  9. phil miller
    phil miller Well-Known Member VCDS Map User
    1,211
    166
    Tuffty do you know if the cam wheel on an ARY is the same as an AGU?
