AEB Exhaust Port Size
Barks Jul 31, 2013
  1. Barks
    Barks Member
    337
    Has anyone got a AEB head on the bench that they can measure the true exhaust port size?? (Mine is fitted and I want to do some porting port on a 'Chinafold' before fitting)
    Dave
  2. superkarl
    superkarl MAN OF STEEL
    9,623
    2,488
    I think its 38mm.
    You dont want the manifold matched to the head, you need the head to be a tad smaller than the manifold to prevent/reduce exhaust gas reversion.
    Id take the manifold to gasket size if i were you. I know for a fact the gasket is bigger than the aeb exhaust ports.
  3. Jason.s
    Jason.s Active Member
    2,879
    348
    36mm and 33mm for small port.
  4. Barks
    Barks Member
    337
    36mm or 38mm, I have got a gasket so I can certainly measure that size.
  5. Barks
    Barks Member
    337
    BTW Exhaust gasket is 41mm
  6. JimS3
    JimS3 Active Member
    736
    72
    Yup, just measured my AEB head, the exhaust ports are 36mm.
    The AEB exhaust manifold measures 38.5 though, not that it's any use on a transverse car.
  7. superkarl
    9,623
    2,488
    If you leaving the head at 36 then its prob only worth having the mani 1 or 2 mm bigger.
  8. Barks
    Barks Member
    337
    Perfect guys, just the information I require, a slight step head to manifold then, thanks very much for you time.
