As mentioned in another post, I have to replace the clutch in my AEB engined 1.8T Quattro.
This is my (low key) trackday car, and I am wondering what would be a good way to upgrade the clutch without having to import anything too fancy, as the freight to NZ can often be more than the purchased item.
I should have the car stripped down by the end of this weekend, which will tell me whether or not the flywheel needs replacing as well as the friction and pressure plates.
Is there an upgrade from within the VAG group that will be compatible with my engine? If so I may be able to source it locally.
