aeb big turbo engine breather setups
sam80quattro Mar 14, 2010
  1. sam80quattro
    sam80quattro Member
    146
    are people running anything other than standard as far as the breather setup goes? i was thinking about gettin an agu rocker cover as i noticed the aeb dont have the vent on there but the agu does... is it needed or will the standard setup cope with a hopefull 300bhp? thanks in advance?
  2. Broken Byzan
    13,237
    465
    get a catch tank and route the PCV pipework into it, job done
  3. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    I am tapping the rocker and running a two tube catch from crank case and rocker cover. am venting to atmosphere at to begin with but may tap it back in later
