AEB 1.8t Large Port Cylinder Head
MUSH Jan 22, 2012
  1. MUSH
    MUSH MUSH Developments Ltd.
    713
    12
    This came from a passat 1.8t with 93k miles. Ran fine but car had a side impact.
    Now surplus to requirement as my setups in and running so i can clear my hoard.
    Its got a minter rocker thats been vapour blasted so is immaculate.
    £150
    Located Newcastle but can courier for £20
    Pm or ring 07903604156
  2. jitvv
    jitvv Active Member
    198
    58
    Hello mate, Is this still for sale? would you know if this would fit a AMK? or would i need to modify it?Thanks
  3. Westy
    Westy Well-Known Member
    17,443
    1,105
    It will fit on any other 1.8T block but you will need to swap over your cams and also VVT unit.
  4. s3gazz
    s3gazz Well-Known Member
    1,383
    105
    Do u have to swop cams over or can u use the same ones in the agu or aeb head
  5. Westy
    17,443
    1,105
    I've been advised to swap mine over but that may have only been due to knowing the history of my cams. You definitely will need to swap over the VVT unit and this will involve having a few mm machined off the side of the block like this:
    but should be flat like this...
  6. MUSH
    713
    12
    Now sold guys thanks.
    Fyi, i never had the head machined to get rid of the stepped section. I simply didnt fit the supplied washer that comes with all 06a cambelt kits. It all lines up perfect.
  7. Westy
    17,443
    1,105
    Yeah I notified the buyer of it ;)
    I'll let him know notto worry about machining it.
