Advise needed.. how to fit mass air flow sensor.
guzzy_431 Mar 22, 2013
  1. guzzy_431
    guzzy_431 Member
    107
    Hey pepz,
    I'm looking to atempt to fit my new mass air flow sensor unit, at the weekend. I've scoured forum to see if anyone else has done this before, on how to which I couldn't find.
    If anyone could shed some light on how it is done & what to look out for, much appricated.
  2. gen.heinz guderian
    gen.heinz guderian Well-Known Member
    1,346
    126
    It will take 10 mins at the most,all you will need is a philips screwdriver and a pair of grips. Take the Clip and pipe off of the MAF take out the 2 screws holding the MAF to the airbox Put in new MAF replace screws and pipe/clip job done.
    Just make sure you note direction the MAF is fitted .
  3. Blackcupraa
    Blackcupraa Member Team Ibis VCDS Map User Audi S3
    188
    14
    You may also need a small falt bladed scredriver to remove the Electrical connector to the MAF itself. Just put it in and slowly twist.
    As has been said before, it's a very straight forward job, 2 screws in the airbox and a jubilee clip on the TIP. :)
  4. Pabl0
    Pabl0 Member
    140
    Take the tools needed with you if your getting a exchange unit and you can do it in the car park outside audi/GSF as it takes minutes.
