Advice with vibration....
mingyar Apr 14, 2010
  1. mingyar
    mingyar New Member
    Hello, Im having a problem with my 2003 S3, Its only 40,000 Miles , so, when I drive at 75mph I have a vibration in the steering wheel, I think that its because my wheels need to be balanced, but also when I brake in speeds from 60 to 40 mph I also have a vibration in the steering wheel, but I dont have the vibrations below 40mph, this can be also caused by the unbalanced wheels?
  2. JD09
    JD09 I'm not modding, I'm improving VCDS Map User
    3,096
    46
    First point, don't drive at 75mph?
    On a more serious note, sounds like tracking to me rather than wheel balance. You are more likely to get vibrations all the time if the wheels are not balanced correctly.
    When was the last time you had the car setup/tracked?
    Also, re the braking question, checked your pads/discs? That is the most likely cause I would have thought.
  3. DaveA3
    DaveA3 Audi A-Trizzle!
    2,370
    15
    balancing i would say i used to get them bang on 80mph all the time when i had part worn tyres that couldnt be balanced. if ur tyre wear is even then definatly balancing. if your tyre wear is uneven then get the tracking done
  4. JD09
    3,096
    46
    Tracking will affect the car (with vibrations) regardless of tyre wear Dave mate. But camber would be the usual cause of uneven wear.
  5. Matt82
    Matt82 Active Member
    2,365
    tracking does not create vibrations
    unblanced wheels will cause vibrations
    as for the braking. warped discs perhaps
    get the balancing done on the front wheels to start wtih though
  6. s3_stig
    s3_stig Member
    376
    Secound matt82 on this one
  7. JD09
    3,096
    46
    Of course bad tracking creates vibrations. If the wheels are not aligned properly, it causes exactly the same issue as an unbalanced wheel.
    If your wheels are pointing in different directions, as the incorrectly angled wheel turns it will pull the car slightly to one side or the other. At the same time the other side will be doing the same.
  8. fingermouse
    fingermouse thats me
    4,013
    116
    first guess id get the wheels balanced,
  9. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    it could actually be both, if it is speed related usually tracking.....
    tracking usually is steering wheel shake, vibrations can be any wheel and usually rear
  10. mingyar
    mingyar New Member
    Thanks for the answers, I will take the car to balance this weekend, I was wondering if maybe it need new bushes?
  11. s3_kev
    s3_kev Stage2'd!!!!!!
    2,002
    23
    i have never experienced steering vibration due to tracking its always due to buckled wheels or balancing issues, ive seen lots of people mention tracking as a problem but ive never seen anyone go get tracking done and its fixed the problem also ive never done traking to fix the problem before either. the wheels would have to be massivly out of alignment to be a factor as in noticably out possibly due to accident/impact damage,
    camber causes very little extra tyre wear also unless excessive camber is used its more to do with tracking as the wheels will scrub as your pulling away or braking more with them being either toeing in or out, i have 1.5 degree camber up front and tracking 2degrees out and my tyres have started wearing on the inner edges where as the rear setup is more camber at -2degrees with tracking parrell no tyre wear at all :icon_thumright:
  12. s3_stig
    s3_stig Member
    376
    It's not tracking if ur brakeing and it's pulling to one side than it could be tracking
    get them balanced I had the same problem when I had a tyre changed they never balanced the wheel propley
