Advice RE: TSB
S3 Big Andy Sep 18, 2008
  1. S3 Big Andy
    S3 Big Andy Stealth Beast Baby Yay
    725
    Hi, is this common knowledge in the UK? as I am having real problems with my car..
    Technical service bulletin, from another forum
    http://forums.fourtitude.com/zerothr...2605520&page=2
    It's 01-08-05 jan 23, 2008 2017064
    Basically says you get cold start misfires
    Try swapping spark plugs and ignition coils between cylinders
    Check compression and leak down of affected cylinders
    verify fuel quality
    swap injectors
    If all else fails:
    replace all 8 rocker arms and 8 hydraulic equalizing elements (lifters) of the affected exhaust side.
    Parts:
    022109423D Engine - Cylinder head & valves - Valve lifters
    06E109417F rocker arms ($20-$15 each)
    06F103483D Engine - Cylinder head & valves - Valve cover gasket ($15-$11)
  2. stoke_audi
    stoke_audi Active Member
    2,243
    19
    Hi Andy,
    just spoke to our master technician,
    the only thing we replace over here is the coil packs and spark plugs
    and we usually find out its the coils packs.
    wouldnt try swaping them around, just replace with latest ones
    Dave
