Advice please?
Leo786 Jan 14, 2014
  1. Leo786
    Leo786 New Member
    Hi guy's
    I'm after advice please i have a A4 B6 2002 and whilst driving along a road I hit a pot hole front drivers side wheel, immediately after that it seemed that something broken as the engine noise changed and sounded as if the exhaust had fallen off and also whilst on idle the vibration on the car is immense
    I took to a local garage and a quick look by the mechanic who informed me that the cat which goes into the manifold was leaking with mechanical background the worm went ahead after collection the car still sounds the same vibration, engine noise as if the exhaust is broken and also when I change gears air is releasing from somewhere as if I've got a dump valve fitted which I haven't.
    Any advice to what I should look out for will be appreciated as garages charge but do not confirm that this the exact problem.
    Thank You
  2. IanFM
    IanFM Active Member quattro Audi A5 TDi
    452
    81
    Hi it might help if you give us a bit more info like what engine you have?
  3. Leo786
    Leo786 New Member
    Hi Ian it's a 1.9tdi Sport
  4. S4_dan
    S4_dan Fire up the Quattro! VCDS Map User
    2,699
    157
    Check all inlet pipes and exhaust system for any loose connections or holes.
