Advice please is it allready mapped?
FL1X Jul 16, 2009
  1. FL1X
    FL1X Member
    61
    hello
    I have a 55plate A3 2.0TDI engine is in discussion at the moment
    in a attempt to figure out the performance i run some tests with vag com the end results are as follows;
    Torque: 410nm
    Boost: 21.9 PSI (peak)
    can anyone tell me if this is standard for either the 140 or the 170ps engine?
    Im starting to wonder if my car has been remapped previously to my owning it.
    any advice would be muchly appricated if anyone can run chassis/engine numbers let me know as i have that data.
    FL1X
  2. bluequattro
    bluequattro Member
    411
    hi m8 can u tell me how u found these figures using ur vagcom?
    cal
  3. FL1X
    FL1X Member
    61
    errrm i had someone else recording the data as i drove but its in engine then just scroll through untill you get rev / torque / torque and the other module was 34 i think its revs boost boost there are two that look the same one is atmosphere and boost the other is requested boost and true boost.
    Hope that helps
  4. hollow
    hollow Well-Known Member
    1,404
    162
    log channels 3,8,11
  5. bluequattro
    bluequattro Member
    411
    cheers guys :)
  6. Sparky28
    Sparky28 New Member
    must be remapped to get a figure like that unless its wrong?
    whats your 0-60 time?
  7. FL1X
    FL1X Member
    61
    its about 8seconds tops out at 137 on a straight runway...
    which puts it perfectly in line with the 170ps as the 0-60 was recorded in car with a stop watch and the 170ps should do 0-62 in 8 dead
    me wonders....
    i just dont know how to check execpt giving it to audi and getting them to check it for me which i dont fancy doing.
    It doesnt feel remapped ive driven mapped cars and the powers just not there its quick mind you but its not uber quick.
    F
  8. FL1X
    FL1X Member
    61
    Bump
  9. FL1X
    FL1X Member
    61
    update:
    Ive emailed audi but no one seems to be able to help me there either :(
    any one got a standard 140 or 170 and can run these tests?
    please
    thanks
    FL1X
  10. 10blazin
    10blazin HYPERDRIVE NEEDED
    3,301
    no point emailing audi you already bought the car lol ... i bet it would be different if you were buying the car and had been for a test run and wanted to know.....
  11. Staz
    Staz is a retronaut Staff Member Moderator VCDS Map User
    6,206
    64
    I'm 99% sure they didn't make the 170 when your car was made mate.
  12. AuldReekie
    AuldReekie Member
    770
    Right I was bored ok. But, I checked on Audi's used car configurator for the same spec as yours and every one of the 43 cars :blush: I checked was 140 bhp and 320 Nm @ 1750 RPM. May be a fluke, but looks like Staz is correct.
    Also looks like someone has been doing the upgradings on your ECU too; I would imagine 90 Nm is over and above factory tolerancies. Good news for you, but maybe not for your insurance.
    Edit: this is the first 170 I can find - Jul 2006. Even that is only 350 Nm.
  13. Staz
    6,206
    64
    I ordered my previous A3 in July '06 and I remember the 170 was a brand new option on the A3 range. I don't think there are any that aren't single grill either.
  14. AuldReekie
    AuldReekie Member
    770
    Jinx on my edit. Dead leg for you. :laugh:
  15. Staz
    6,206
    64
    lol bummer!
  16. FL1X
    FL1X Member
    61
    Hmm thanks for all the replies guys it's kinda disapointing knowing that it's as good as it I'll get without moving into silly monies I suppose I could get Audi to replace the clutch drive chain and all the oils and put it back to standard as they miss sold me the car lol next service paid for and that amount of toruqe cannot be good for a standard clutch!
    Think I will go into the garage on Saturday and see what I can muster
    F
    ps anyone know of a surefire way of checking the ecu map?
  17. redbutcher
    redbutcher Member
    649
    That torque figure sounds a bit high.
    I've logged block 20 on mine which records engine speed and engine torque amongs other things.
    I then used this from the ross-tech site to give me a figure of 363Nm of torque or 172bhp. Mine is a remapped 140.
  18. Johnny Bravo
    Johnny Bravo 6+1 Gears Bronze Supporter Audi A3
    898
    69
    410 NM of torque is more than the 170HP has. I'm sure the engine was remapped.
    I think the 170HP engine has about 370NM and the 140 one has 320NM.
  19. kaz219
    kaz219 Active Member VCDS Map User
    1,808
    Thats defo remapped mate....
    The 140 wasnt produce till 2006 and it has the straight tailpipes as opposed to the ones that curve down.
    If you look on the sticker in your boot or the sticker in your service manual, it should say 103kw which is 140ps.
    Also, if your engine code is BKD, it will be the 140ps.
  20. A2!
    A2! Member
    32
    Stick it on a rolling road. £30ish a run will give you an answer
  21. FL1X
    FL1X Member
    61
    That's not a bad idea mate I thought rr cost quite some money but if it's that cheap worth it just to get the answer
  22. millsy4002
    millsy4002 Active Member Team Sprint quattro
    253
    87
    My 07" 170 was 360Nm standard
  23. Cambaines
    Cambaines Active Member
    841
    196
    43
    Did you just bring up a thread from 7 years ago? some good going lad!
    millsy4002 likes this.
  24. millsy4002
    253
    87
    It was on my tapatalk feed, never even looked at the date lol
  25. Cambaines
    841
    196
    43
    in your defence I've done that before, don't have a clue why it does it sometimes, thought you were busy in work getting through the hundreds of threads on the 8p section
  26. millsy4002
    253
    87
    Reading 10 years worth of forums at work is a better use of my time than working
  27. Cambaines
    841
    196
    43
    I grant that! It's honestly nothing I've ever done easily get lost for hours on here, especially on some peoples build threads
  28. nluk100
    nluk100 Active Member
    916
    163
    43
    VagComs' torque figures are only estimated. You've logged boost (was it actual or requested?), which you quoted as 21.9 PSI peak which is exactly 1.5Bar. However, VagCom adds in atmospheric pressure (1bar) which means yours is running 0.5 bar peak, which seems low even for a standard car.
