Advice on Vacuum Hoses
S3 CYP Dec 8, 2009
  1. S3 CYP
    S3 CYP Active Member
    147
    27
    Would any of you be able to confirm that if I was to change the vacuum hoses like in the follwoing picture example will there be fluid loss or de-pressurisation if I attempt the same.
    I have some silicone vaccum hoses lying around in various sizes that I found while having a clear out yesterday and it just got me thinking that I could use it on the s3 engine bay.
  2. Welly
    Welly VX220 SC Driver :)
    10,696
    128
    Should be fine mate, start with the vac hoses and make sure you get a good seal. Also, consider doing this (http://www.audi-sport.net/vb/showthread.php?t=84402) at the same time.
    I'm in the process of doing mine at the moment amongst other thing, but bad weather keeps stopping me!
  3. tompearson
    tompearson It's all in bits
    219
    Are this sizes in the pic correct? You state 4mm in the N249 thread Welly and this shows 3.5mm - or does it not really matter?
  4. Welly
    10,696
    128
    It's close enough, silicone hose is reasonably flexible and will stretch over without too much problem... If not, then a kettle and hot water will aid you... :)
  5. S3 CYP
    147
    27
    Thanks Welly for the reply. I am ready with the TIP, top boost hoses and the newly found silicone but your right the **** weather makes it a pain in the a*** to crack on with.
    With regards to the 3.5mm your have troubles getting that in this country, only american sites stock that size. 4mm will be fine its just means that you have to use clips with 3.5mm you may not need to as it would be a very snug fit.
