Advice on spending money on the right things for my s3
Alex_Wil Mar 4, 2014
  1. Alex_Wil
    Alex_Wil S3 - DSG - Black Edition - TTE Hybrid Turbo Regional Rep
    1,212
    839
    certainly not dropping in power at the moment! - think ill get the gfb dv+ and fit it myself in good time - get it now and wont hurt so much when I buy more extras in the future ;) haha
    Cheers for your help !
  2. ninjakid
    ninjakid Member Team Silver Audi S3
    You can find which rev dv you have by looking at your current one. Its right at the front of engine slightly right of centre. You might have to lift engine cover to see it, or shine a torch at it and look for part number. The last letter at the end of part number will tell you which revision you have. Takes 5 mins to do.
  3. Alex_Wil
    1,212
    839
    Cheers- will check after work and see what it is - going to get gfb DV+ put on in next couple of weeks after reading good things about it
  4. prt57
    prt57 Well-Known Member
    849
    262
    The problem is getting off the engine cover. It really is a strain, especially if you are little like me!!
    This might help a bit:
    OOOO-A3: How To Remove the Engine Cover / Stock Airbox
    Put some sort of rubber grease on the spigots before refitting to enable easy removal in the future.
  5. Alex_Wil
    1,212
    839
    I got the tts engine cover on mine now - got the amd cai so old one was taken of so hopefully can see it fairly easily!
  6. ninjakid
    you should see it then as the oem cover has a slight over hang at front and the dv is tucked in under it. but as i said you should be able to see it using a bright light. P/N for rev d is - 06H 145 710 D
    Here's a pic of dv in engine bay. (Thanks to Warren_S3 for pic)
  7. Alex_Wil
    1,212
    839
    Ill check this out when i get to my car and hopefully its a rev D .
    Alex
  8. Alex_Wil
    1,212
    839
    Had a check this morning and its a Rev D - Got car booked in on the 5th to get the GB DV+
    Just deciding now if its worth getting DSG software update ?
    Any opinions welcome!
