Advice on spacing wheels. 2.0tfsi sline sporback 18"speedlines
rickypj Jan 16, 2012
  1. rickypj
    rickypj Member
    Hi all,
    I've been Thinking for a while that the rear wheels on my sportback appear to sit quite far in the arches. Should I space them out and if I do how much? and do I need any sort of re alignment after? Is it quite a normal thing to do or have I possibly got the wrong wheels fitted
    Any help would be great, thanks
  2. FranA3
    FranA3 FMDETAILING Site Sponsor Regional Rep Gold Supporter Team Brill Red Audi A3
    7,264
    363
    i recon 12mm will do it nicely if they are the standard offset wheels which are et54 , N8 is the wheel man he will advise you better soon enough
  3. Brodster
    Brodster Well-Known Member TeamMisano Team V8 Audi RS4 Audi Avant Owner Group s tronic
    3,553
    896
    I was going to ask the same question. Having posted pictures of my S3 and compared it to others I would like to alter the stance of the car by fitting spacers just to give it a more aggressive stance. Is it as simple as wheels off, spacers on and longer bolts fitted and then balance wheels??? My car is standard 8P2 S3.
  4. FranA3
    7,264
    363
    yep easy as wheels off spacers on , get longer bolts (if required) then wheels on job done , don't think you need to balance the wheels again as they should be balanced anyway
  5. Brodster
    3,553
    896
    OK then thats sorted then. What is the best size to go for......10mm or 12mm and should front and back be the same size. Just want to give the car a more aggresive stance.
  6. warren_S5
    warren_S5 Moderator Moderator VCDS Map User
    7,210
    2,488
    Personally on S3 I'd go for 10mm. With it being lower than the other models any more than that will result in rear arch rub. You could go 12mm but it will mean you need to whip the rear arch liner screw out of the top of the arch.
    McGard locking bolts (around 40mm), and then some extended wheel bolts M14 x 1.5 (36-40mm) will be fine.
    Make sure you get the right sort (radius fitting bolts) as otherwise you'll end up with terrible wheel wobble!
    You could go 12mm on an A3 with higher standard suspension.
  7. DPM
    DPM Site Sponsor Site Sponsor
    5,065
    224
    On the A3 the best and most popular option is 10mm front and 12mm rear.
    Give me a shout if you need any prices or info.
    Damian @ DPM Performance
