Advice on removing secondary air pump please!
mark_sarah May 22, 2010
  1. mark_sarah
    mark_sarah Limp mode!
    203
    I will be removing my Secondary Air pump, can anyone advice me, or give me a stupid proof guide to the removal procedure?
    Am i right in saying i have got to remove this? And this is where the Forge blanking plate goes?
    Has this pipe got to be blanked off, or re-routed?
    The pipe above goes to here, and then goes up to another part of the engine. There is also another pipe which is blanked off on this unit, should it be?
    The pipe that comes out of the unit above then goes here. Is this to be blanked?
    Before anyone comments on the state of the pipes, they have now been changed, as these seem to be the cause of some of my problems.
  2. rossbrownlee
    rossbrownlee Ross_S4
    719
    Why do you want to remove it?
  3. mark_sarah
    203
    Because it has water dripping out of it, and it is registering a fault on Vag com.
    Seems cheaper to remove it..
  4. Imteyaz
    Imteyaz 6th Gear
    535
  5. rossbrownlee
    719
  6. mark_sarah
    203
    Thanks to everyone that sent me links to help me remove the SAI pump ect.. Did it today and it was a doddle.
    However! Even though the fault code is no longer poping up, the problem with the irratic boost is still there. And it has thrown up 2 different fault codes!
    Starting to pea me off now, and help would be greatfully appreciated.
  7. rossbrownlee
    719
    post up the fault codes you are getting.
  8. mark_sarah
    203
    I re-scanned the car today, and ended up with more new faults:
    3 Faults Found:
    16795 - Secondary Air Injection System: Incorrect Flow Detected
    P0411 - 35-10 - - - Intermittent
    16518 - Shareware Version. To Decode all DTCs
    P0134 - 35-10 - Please Register/Activate - Intermittent
    17521 - Shareware Version. To Decode all DTCs
    P1113 - 35-10 - Please Register/Activate - Intermittent
    Readiness: 0000 0000
    Address 35: Centr. Locks
    Controller: 8L0 862 257 P
    Component: CV-Pump, Alarm, RC D13
    Coding: 13130
    Shop #: WSC 00000
    11 Faults Found:
    01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
    35-00 - -
    01371 - Shareware Version. To Decode all DTCs
    35-00 - Please Register/Activate
    01374 - Shareware Version. To Decode all DTCs
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    01369 - Shareware Version. To Decode all DTCs
    01366 - Shareware Version. To Decode all DTCs
    01365 - Lock/Unlock Switch: Interior
    29-00 - Short to Ground
    00955 - Shareware Version. To Decode all DTCs
    09-00 - Please Register/Activate
    00956 - Shareware Version. To Decode all DTCs
    01134 - Alarm Horn (H12)
    76-00 - Terminal 30 missing
    01134 - Shareware Version. To Decode all DTCs
    49-00 - Please Register/Activate
    The SAI fault has now been rectified. The other faults are new to me..
  9. The Stig
    The Stig Member
    33
    did you place a 330 ohm 10w resistor?
  10. rossbrownlee
    719
    check out this link
    Will help you with the fault codes. had a quick look couldn't find some, maybe cause it is shareware version?
    try clearing them and then scan again to see what comes back up. you will be stuck with the SAI fault codes though.
  11. mark_sarah
    203
    Cheers guys..
    Will try tomorrow.
    Have'nt put the resister in yet, ordering on friday.. skint..lol!
  12. mark_sarah
    203
    Since i have removed the SAI, i have noticed the revs take a while to settle after the car is rev'd. I thought it was because my DV was shagged, but i replaced it today with a Forge replacement, but the rev's are still un-settled.
    Any ideas on what may be causing this?
    I have checked vag com, but it is still only throwing up the SAI fault becuse i am not able to wipe fault codes.
  13. rossbrownlee
    719
    vacuum hose leaking?
  14. mark_sarah
    203
    I need to clarify where this pipe is suppose to go, highlighted in red. At the moment this is just blanked off. Is it suppose to be connected elsewhere?
  15. rossbrownlee
    719
    That is the vacuum feed to the N112 SAI solenoid mounted on the plate under the intake manifold next to dipstick tube.
    Since you have removed your SAI then it should just be blanked off.
  16. The Stig
    The Stig Member
    33
  17. Matt82
    Matt82 Active Member
    2,365
    is the SAI the thing that ends up chattering on cold idle?
  18. mark_sarah
    203
    Possibly.
  19. Welly
    Welly VX220 SC Driver :)
    10,696
    129
  20. ikbenben
    ikbenben Belgium S3 driver
    105
    Mine also makes that sound on cold idle. Strangely I don't have the SAI pump ???
  21. Matt82
    2,365
    as in youve completely removed it?
  22. ikbenben
    105
    As in my car doesn't have it standard. Maybe the previous owner already removed it, i don't know.
  23. rossbrownlee
    719
    The chattering you are referring to sounds more like the evap solenoid. It is located on the charcoal canister next to power steering reservoir.
  24. Matt82
    2,365
    thats suprising. well after a bit more reading, it seems the SAI only functions below a certain temp, the light chatter i get on startup some times i think is from my cam chain. im cleaning the oil pick up this weekend and ill see how that goes
  25. jonny87
    jonny87 Active Member
    1,094
    yes, the sai is supposed to operate on first startup, pumping fresh cold around from the airbox straight to the exhaust system, lowering emissions, once the cat reaches a certain temp it shuts off, seeing as the newer engines (amk & bam) dont have the sai i assume that audi realised it was a waste of time and removed it
    when i removed mine the pump was full of water and grit and grass, chucking a code, replaced the wiring plug with a resistor, no codes, simples
    for anyone wondering about how it affects emissions, i had my mot done a few weeks back, sailed through emissions no problems
  26. coyle
    coyle From Show... to GO
    435
    i fancy having a go at this while my cars off the road, is it pretty easy?
  27. Andrew@A.L.D
    3,879
    617
    Same for me when i took it in for MOT i just made sure it was up to full working temperature and pass easy.
  28. coyle
    435
    Ok, going to remove the SAI pump tomorrow, i've read numerous guides etc, but just want to be 100% sure what im doing.
    So remove the pump, do i have to fit a resistor? if so what spec?
    remove the combi valve, do i have to remove the coolant neck pipe in order to fit the blanking plate? or should i leave the metal pipe connected and blank it at the top by the rocker cover?
    do i leave the n112 valve not plummed in to anything at all?
    does the hose now run from the top of the dumpvalve straight to the inlet mani?
    anything else i should know about or watch out for? its an APY engine
    cheers
    Jon
  29. coyle
    435
    Does it go in to the TIP? so i know whether i need to get something to block the TIP pipe
  30. Welly
    10,696
    129
    Points above ^^
    JudderMan likes this.
  31. Welly
    10,696
    129
    Nope.
  32. coyle
    435
    Ok great!
    Ive got my forge blanking plate. So when fitting it,do i fit it at the top by the rocker cover (like the pic suggests at the top of this thread?) or fit it on the engine hole itself, and if the latter do i need to remove any coolant pipes, as ive seen this in some threads but not others
  33. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Are you doing a "how to" for the guys........?
  34. coyle
    435
    Theres so many of them, wellys done one, its just hard to put everything in place in your head.
    So just making sure and finding out whats what so i dont over complicate things
  35. beachbuggy
    beachbuggy Well-Known Member
    1,931
    201
    RESISTOR:
    If anyone is interested, you need to fit a resistor in order to keep the fault codes away.
    You need a 10w 330ohm resistor, but these are a little hard to get hold of, but a 10w 470Ohm resistor from Maplins will work just as well. cost is 69p. The resistor is quite large, place the two ends of the resistor in the plug socket and then wrap in insulating tape.
  36. S3 finatic
    S3 finatic Limp mode
    106
    Previously mark_sarah
    The blank needs to go on the engine block, that is what its design for.
    Once I put the resisters in place, no more fault codes...
  37. coyle
    435
    Ok, brilliant.do i have to remove the hoolant hose next to where the blanking plate goes to get access?
  38. S3 finatic
    106
    I did'nt need to, but it made it more fiddly.
  39. coyle
    435
    I'll do my best to do it without,as dont want to lose my G12 which i only put in 2weeks ago when i changed my thermostat..
