Advice on how to clean...
Daemon Aug 26, 2012
  1. Daemon
    Daemon Member
    89
    .....my greasy crevices required.
    Need a bit of help on what to use to clean the door hinges and that general area of the inside of the doors as they are becoming a bit dirty and greasy.
    I'm a bit unsure of what to use as I don't want to end up flushing the grease out of the places where it actually needs to be.
    Help please :)
  2. vr6gordy
    vr6gordy Well-Known Member
    2,775
    180
    You could get a soft brush and spray water and shampoo on area then use soft bush to remove dirt then spray clean water to raines
  3. moag
    moag she's no d-turbo
    821
    35
    Water and shampoo won't be any use. You'll need a degreaser such as autosmart G101. Spray on and agitate with a brush then rinse
  4. A4_MaJiK
    A4_MaJiK Azeem
    924
    109
    43
    Shouldn't this area be regreased once cleaned?
  5. AlexGSi2000
    AlexGSi2000 Well-Known Member VCDS Map User
    1,464
    199
    I have used "Gunk" in the past doing this.
  6. Brodster
    Brodster Well-Known Member Team Ibis VCDS Map User Audi S4 Audi Avant Owner Group
    3,548
    883
    I use some snow foam and a detailing brush and let it soak in for about 15-20 mins. Works wonders
  7. Kelza
    Kelza MODERATOR Staff Member Moderator Audi RS3
    3,078
    604
    Hi mark ,what snow foam and car shampoo u using..:)
