Advice on egr valve
Gazthesparky Apr 28, 2012
  1. Gazthesparky
    Gazthesparky Member VCDS Map User
    217
    Hi all
    I've got a a4 b7 2.0ltr TDI and I'm not sure If it's just my imagination or if the engine is vibrating and noisier than usual while stationary
    So I've read alot about cleaning the egr valve on the car so I'm going to have a look
    The cars only done 41 thousand miles but the previous owner ran it on supermarket fuel so think it might be caked up
    First things is do I need 2 new gaskets ?
    Then is it carb cleaner I clean it with
    And finally can I just check is this the valve in the picture and I'm guessing you undo the 3 Allen key bolts the 2 at the top and the 1 underneath ? Then undo the connectors and pull it out to clean
    Do you then just replace the gaskets and bolt it back on ? Do you need to rest anything using vcds ??
    Just got a few nerves as I don't want to try and fix something that's not broken and actually break it lol
    [​IMG][/IMG]
  2. Macdoon
    Macdoon Well-Known Member Team Ibis TFSI Owners Group Gold Supporter Audi A4 S-line owners group
    2,027
    800
  3. Gazthesparky
    217
    Wow thanks I never thought of that how silly of me
    No seriousily I did search spent the whole day researching and even read that thread
    Was just asking for clarification as to the location and if in fact that was the egr valve that I'd taken a picture of because it looks different to picture I've seen of others
  4. Macdoon
    2,027
    800
    Gaz my mate is a mechanic, so i took it to him, he had mine off, cleaned out, new gaskets, back on 45mins (included us talking ****e and tea)
  5. Gazthesparky
    217
    Just been to halfords and the only carb cleaner they have is wynss carb cleaner can it says for petrol engins can anyone confirm if this is ok to clean my egr valve? Or is there a desiel versition
  6. alpesh26
    alpesh26 Active Member TeamMisano
    424
    45
    it'll probably be fine as your not really cleaning the carb with it
  7. madstaff
    madstaff Member
    106
    Wynns carb cleaner will be fine. If you could get 5 litres of brake cleaner that would be better as you can fill up a container with it.
    I filled up something like an old ice cream tub with brake cleaner, and let it soak, then got busy with an old paintbrush.
    A dirty horrible job!!
  8. Gazthesparky
    217
    Well I did it used the a Tin of the wynns carb cleaner. It hasn't made any noticeable difference to the car when it's just idleling it still shake and vibrates the valve was certainly caked in carbon and now I've got black hands to prove it couple of photos of before and after
    Before
    After
    So I'm not sure if the timing is out or it's miss firing so I believe u can check this with VCDS if someone could advice what I have to do to get these readings is be great full then if I could post the results up and if someone would be willing to look them over id be grateful because I haven't got a clue what is normal
    Thanks for the advice up to yet
  9. jaygeezer871
    jaygeezer871 Member
    166
    Gaz, I'm no expert but everything I've read on these threads leads me to believe the symptoms u are experiencing are the dual mass flywheel failing not an engine issue.
    My car does exactly the same, had the injectors replaced, cleaned the egr and will do the maf.
    Sure someone will know better who has had the flywheel replaced, worth doing some more investigation though?
  10. mm707
    mm707 Member
    284
    Mine does the same even though it had a new egr about 12 months ago and have only done about 4k since. Doesn't do it all the time though and I also see the rev counter moving which makes me wonder if mine is the dmf as I can't see how this would affect the actual revs.
    Would like to get it sorted though
  11. raffhussain
    raffhussain Active Member TFSI Owners Group Audi S3 quattro Black Edition s tronic
    282
    95
    mine does the same thing. Ive changed the DMF and clutch but that didnt help. also cleaned EGR, new MAF, New turbo. still the same. i read somewhere that these engines to vibrate on idle and its the way the engine is. im not convinced. its got to be something thats causing it. the rev counter on mine doesnt move but u can still feel the car shake.
  12. jaygeezer871
    jaygeezer871 Member
    166
    The revs dont fluctuate on mine either.
    Surely if the engine was at fault you wolud see the needle moving or hear a change in tone?
    My clutch is def on way out and will see about the dmf when it gets done.
  13. Wrath
    Wrath Well-Known Member
    1,196
    42
    I read they vibrate a little on idle although a few cars had this reduced by an ECU update apparently.
