advice on changing dash and airbags 2009 a3
dallo Oct 9, 2013
  1. dallo
    dallo Member
    139
    looking at buying an a3 2009 front end smash the only thing is changing the dash and airbags can anyone give me some advice and how easy it is and the time is should take me.
  2. @udi A3
    @udi A3 Site Sponsor Site Sponsor VCDS Map User
    1,820
    197
    At a guess, a days labour and vcds?
    Worst i ever did was a citroen zx with aircon. took about 10 hours altogether.
  3. dallo
    dallo Member
    139
    any ideas where I would start?
  4. NHN
    29,341
    1,719
    Well 1st scan with vcds & see what system show issues & then work from there with each system.
    Dash isn't a fun job, but you'll have to strip out everything in front of it 1st.
  5. shady-ninja
    shady-ninja Active Member
    999
    53
    My mechanic told me that the dash is held together with eight bolts.
    Steering wheel and centre console has to be removed first before you
    Can gain access. Its not too hard.
    Then once you bought the airbags you need to get someone to clear the crash data from the airbag module.
    You need to replace the front seat belts if the tensioner has collapsed.
    I know some one in London who can do this without removing the module.
  6. NHN
    29,341
    1,719
    You don't need to remove the dash to get to the airbag module anyway, just the center console. as its hidden behind & below the climate unit, pita to get too but can be removed nonetheless.
  7. @udi A3
    1,820
    197
    modules can be reset and crash data cleared diagnosticly.
    Haynes manual normally does a good write up on dash removal.
  8. shady-ninja
    999
    53
    how bad is the crash
