advice needed re:ABS / ESP intermittent warning lights
gavcav Jan 10, 2011
  1. gavcav
    gavcav New Member
    20
    advice please guys... from reading the forum i've found it's a regular problem.
    tonight my ABS and ESP amber caution lights illuminated and remained on. i got home, had a read of the manual and forum etc and without jacking up the car and removing the wheels, i went to check the car for obvious leaks, damaged wires. i couldn't find anything obvious.
    i started the car up and found the ESP light had gone off. i then went for a short drive and the ABS went off too.
    i thought everything was good again, then they re-appeared for some minutes, then went off again.
    11 days ago i had to replace the rear pads, so i'm wondering if i've disturbed a sensor or not?..if i had, i would have thought i'd seen problems before now?
    what do you think as a first step?.. clean sensors/sensor plugs?..vagcom? (which i don't have so it'll cost me ££'s)...or is it a sign of something more serious? (ABS module).
    i'm not sure what step to take next, so any help would be appreciated...thanks
  2. hades-
    9,481
    646
    1st step is to get it on a scanner and read the codes
    even if there not on they will be stored
    i had this a few weeks ago and it was my battery going dead
  3. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Im in leeds and can get it on the computer for you on saturdays if stuck, it can be many things and a scan will tell you...
  4. gavcav
    gavcav New Member
    20
    thanks lads....s3dave, thanks mate, i may take you up on that..i've never used this vagcom thing, is it straight forward to do?
  5. gavcav
    gavcav New Member
    20
    ok if i pm you s3dave?
  6. s3dave
    10,110
    736
    yes just plug in, pm me if you want it scanned
  7. alijames
    alijames Active Member
    1,024
    Likely to be an ABS sensor, especially as you have just done your rear brakes. Happened to me after doing my fronts last year. They are only ~£15 a pop, so not an expensive fix...
    Cheers,
  8. finesse
    finesse Active Member
    2,805
    or the longitudinal sensor which is part of the ABS system : £150
    bargain :)
  9. madmark
    madmark Member
    173
    i got the same problem on my a3 can drive 4 miles with lights on then switch off and restart the car and they stay off for a while doing rear brakes today and discs also having a scan done will post any codes later today
  10. S3 Rav
    S3 Rav Well-Known Member
    2,825
    30
    This happened to me and was one Of my throttle sensors. Cost about £100 from midland VW to fix.
  11. madmark
    madmark Member
    173
    done readout came back as front o/s abs sensor this problem started when i replaced front discs so have cleaned sensor and ring been for a spin and so far so good hope this helps if it comes back on will replace sensor unit cost around £15
