Advice needed, problem with air conditioning.
ray83 Apr 12, 2014
  1. ray83
    ray83 New Member
    Hi guys, I have a problem. Yesterday my air con stoped working. A/C button wasn't switching on and no air was coming out. I took it to get recharged. Now a/c light comes up. But it still plays up. Its not letting any air out for few minutes, then everything works fine for few seconds, then again stops and all the way around... kwick fit (where I regased air con) said that it will be ok when gas will start to circulate properly. Was driving it all day but it's same. Any ideas? ;)
  2. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group s tronic S-line owners group
    4,047
    792
    You need to get VCDS and read the fault codes off the HVAC (Climate control) system.
  3. Jeeves
    Jeeves quattronly
    117
    Coincidentally I had the same (I think) issue yesterday, and a VCDS scan showed a faulty A/C pressure/temp sensor. Any idea how easy this is to replace and what sort of cost?
  4. ray83
    ray83 New Member
    My started to work again. Just like that, was thinking to take it to audis, but now feel confused...
  5. B5NUT
    4,047
    792
    Get the car scanned, it will most likely end any confusion.
