Advice needed before buying
MattW86 May 23, 2009
  1. MattW86
    MattW86 Member
    84
    Hi guys,
    I have my heart set on a 97 A3 1.6 sport as my first car. I have found the car i want to get and the price and mileage are fair (Price £1595/,mileage 118K).
    I would be most appreciative of any and all information of what bad points to look out for and what major things i need to check with the car. Unfortunately the mechanical workings of a car are not my strong subject (home cinema nut at heart).
    thanks in advance :sos:
    Matt
    (p.s sorry mods if posted in wrong section)
  2. Zenin
    Zenin Member
    123
    ok seems like you are in my position me but three months back, leme provide some hindsight.
    i got my audi a3 1.6 1998, black with leather with 140k milage and full audi service history. for £1500.
    so check that it does have a full audi service history, if like me ure a perfectionist and a obsesive cleaner type guy, then the scratchs dents and odd bits, stuff like paint chips that cant be repaired by yourself will become more apparent once u have the car, and you may or may not get annoyed by this.
    if u seriously have the money i HIGHLY recommend getting an s3 or a 2000 onwards A3. i am starting to wish i had waited and saved up a bit more for a newer model or s3.
    (mainly due to these forums :banghead:)
    as for faults, my car doesnt start quickly on a cold day, so i still need to change spark plugs and leads. so check that works on yours before buying, check that the rear window wiper works, especialy the water jet(common fault) but it may help bring down the price if it doesn't work.
    also another silly thing is check the car had its jack and spare tyre, mine didnt have a jack, helped bring the price down.
    thats all for the a3 1.6 specific stuff, im still a newb, but my best advice is just check this site completly b4 buying, lots to learn, and it may help u decide on a model.
    ill let the eltie guys take over now...
  3. s3_kev
    s3_kev Stage2'd!!!!!!
    2,002
    23
    dont just set your hart on one perticular car go viewa few before choosing is my advice as other cars may be speced differently etc, theres no rush if its your 1st car. id also agree go for the facelift model if you can afford it as if your going to use this stie alot then your end up upgrading the lights front and rear which will cost you in the end and its more likely to comewith leather seats from std
  4. Essflee
    Essflee Well-Known Member
    2,144
    67
    If it's your first car I stick with your choice of a 1.6 as the insurance will be sky high if you got any at all...seems a lot people seem to run before they can walk...you don't want something to powerful because you'll make mistakes, we all do...
    Don't know much about the 1.6 engine but body work you can check...ie rust on roof lining and bottom of doors, service history would be good to...
    Goodluck with your purchase...
  5. reptor245
    reptor245 Active Member
    1,168
    Bear in mind you will need spare money in the bank and audi`s are famous for being the fastest way to empty your bank account.
  6. Zenin
    Zenin Member
    123
    oh and ure right about insurance, the a3 1.6 is my first car i pay £1100 for fully comp, im 21 and held licence for one year.
    not sure what ure circumstances are matt, but always get a insurance quote first. :)
  7. A3Tom
    A3Tom Smell my finger.
    3,504
    14
    Make sure its had the cambelt and water pump changed.
  8. JJBS3
    JJBS3 Member
    Thats women surely? :undwech:
    Good luck with your first purchase...as said above, we all make mistakes at the beginning! ( I certainly did, and was thankful that it was a 75 quid car heheeh):redface:
  9. Dansmith
    Dansmith Member
    461
    are u mad?? an s3 as a first car?? Ive been driving 6 years with 4 years no claims and no points and i struggled to get insured on my S3! to be hounest i think the 1.6 could be hard to insure! im sure it must almost be hitting 2k on ur own insurance! i used to have a 1.8t after 3 years of driving and that used to cost me a stupid amount to insure its not worth it!
  10. MattW86
    MattW86 Member
    84
    thanks for the reply's lads. to answer the insurance question roughly working out at 1800 full comp. ( i'm a late bloomer spring age of 23).
    thanks for the info, i'm going to run an HPI check on the car to see what has happened in its lifetime.
    Unfortunately have to wait till monday to have a gd look at the car, thank god i had holidays booked.
    P.S again any and all info/recommendations/advice most appreciated.
    Matt:happy:
  11. voorhees
    voorhees Moderator Staff Member Moderator DSG
    16,155
    1,987
  12. bhavin1986
    bhavin1986 BBP
    464
    Ask if the cambelt and water pump has been changed. Check for service history and receipts of work done. Also check under the car for any leaks etc. When you take it for a test run, check the temp guage shows the engine heats up to 90, and check for a steady idle and no rattles. Look at the spare tyre and for jack etc as advised above. Test all the electronics inside the car too.
    Main thing is to be patient and wait for the right one to come along.
    I was unlucky and bought a it of a lemon. So far I've hadto replace the gbox, thermo, temp sender, head unit, CD changer, and quite a few other bits that I can't remember atm.
    Good Luck...and it'll be worth the wait.
  13. Dansmith
    Dansmith Member
    461
    also on a3's of an older age its quite common for the bushes to go! its not too pricey a repair but if the ride seems particually hard but bouncy it could be that!! otherwise what the guy said about the temp gauge is a gooden!! my old a3 never seemed to raise to temp! i think it just was a dodgy gauge but it would be bloody expensive to fix!
    Peronally I would also look for one with leather as the interiors (in my opinion) are flipping hideous otherwise!
  14. evilbow
    evilbow Member
    188
    should the car run at this temp? mine runs at 60 only goes to 90 when in traffic
  15. Essflee
    2,144
    67
    Yup, should sit on 90 once warm, if it doesn't it'll be your temp sender or thermostat...
