Advice/General Consensus Please - Spacers
I'mRonBurgundy? Jul 28, 2008
  1. I'mRonBurgundy?
    I'mRonBurgundy? Lets make that kitten purr...
    554
    Evening all
    Read various threads on here recently and H&R hub-centric seems to be the way to go but what size?
    I've got standard s-line suspension and wheels with no plans to change either.
    Also should front and back be the same size/width or should I go wider at the back?
    Ta
    Ron
  2. jonnyc
    jonnyc Member
    858
    10mm front and 15mm rear seems to be a nice set up
  3. richs2891
    richs2891 I cant spell !
    441
    as I cant be ***** to remove the screw / modify the rear wheel liner and as I tend to travel on lots of bumpy roads then I went for 10 mm all round
    Richard
  4. jamiekip
    jamiekip Guest
    I stuck with 10mm alround for the same reasons, basically I knew there would be no rubbing.
    Having seen jonnyc's car I can safely say that the 15mm on the back does look better!
  5. RobinA3
    RobinA3 Well-Known Member
    1,828
    47
    Has anyone run 15mm rear spacers with a 35mm drop on standard wheels?
  6. edition
    edition Active Member
    1,426
    How much are 4 10mm h&r spacers then?
  7. RobinA3
    1,828
    47
    Hubcentric ones you are looking at around £60 a pair, the cheapest place to get them is US ebay.
  8. RobinA3
    1,828
    47
  9. edition
    1,426
    They look good he also does 10mm ones.
    What about 10mm on front and 12mm on rear has anybody made that work without rubbing?
  10. K-Dash
    K-Dash Member
    156
    anyone got any before and after pics.
    pre spacers - post spacers?
  11. mechanic69
    mechanic69 Well-Known Member VCDS Map User Gold Supporter Audi S3 DSG
    1,504
    567
    My 3.2 sport 54 plate.
    Fitted Eibach pro kit springs, which is 20-25 lower than my original sport springs.
    18" S3 wheels.
    H&R spacers 10mm front and 15mm rear spacers (kit from TT Shop has everything you need in one).
    Before - there's a slight shadow so it's not as clear as I'd hoped.
    After - It's as low as I wanted to go and no rubbing issues even on bumpy roads
  12. I'mRonBurgundy?
    554
    Thanks for the pics mechanic.
    Anyone know how much lower the standard s-line suspension is compared to the sport? Just trying to gauge where mechanics sits in comparison.
  13. MarcQuinlivan
    MarcQuinlivan Active Member
    2,539
    think it is 10mm with the s3 being a further 10mm lower. the sport will be 15mm lower than the standard car.
  14. K-Dash
    K-Dash Member
    156
    if like mechanic said he has the eibach springs on it should only really now be s-line ride height. its what have on my sport and can notice a drop but i'd only say to s-line height.
  15. I'mRonBurgundy?
    554
    Cool - Thanks guys.
    That's definately made my mind up. Just waiting on RobinA3's group buy price now.
  16. mechanic69
    1,504
    567
    Sport is 15mm lower than standard
    S line is 25mm
    S3 is 35mm
    So the eibach springs take it to between S line ans S3 and once settled are closer to S3 height.
    K-dash did you do maths at school??
