Advice 1.9 conversion
S3 D2HTY Aug 25, 2010
  1. S3 D2HTY
    S3 D2HTY Member
    122
    The garage rang me a told me the damage and it was the block needed to come out and be rebored. :(
    I am looking at going dwn the 1.9 route (83mm pistons)
    Correct me if i am wrong but i wouldnt be able to use the standard head gasket? What head gasket would i need?
    Also are there another bits i would need for the conversion?
  2. <tuffty/>
    20,904
    3,713
    You 'can' use the std head gasket but the alternative is to use one from a non turbo 1.8 20v (Bill at Badger 5 runs a 1.9 20v is his Ibiza race car)... can't remember the part numbers off hand but some more info is available here:
    http://www.audi-sport.net/vb/a3-s3-forum-8l-chassis/75685-lots-big-turbo-high-power-info.html
    I personally wouldn't go above 82.5mm on a road car....
    I don't know what effect the increase will have on the fuelling requirements of the map but the ECU should be able to adjust to suit....
  3. badger5
    9,405
    1,945
    82.5mm pistons are the max for std head gasket
    do you "need" to go 83mm?
  4. Andrew@A.L.D
    3,873
    609
    83mm Pistons then you will need a N/A 2.0 20v head gasket
  5. S3 D2HTY
    S3 D2HTY Member
    122
    I was just thinking that while i am there. I might aswell go for the 83mm but if i can go for 82.5mm and stay with standard gasket i'll do that :icon_thumright:
    Cheers guys.
