ADR engines
951 May 15, 2008
  1. 951
    951 Member
    530
    Ive been offered a 97 a3 1.8 which needs a new head .The engine code is ADR which im told on the a3 forum is from the a4,which models were fitted with the ADR engines and does it have to be the same code head that goes on it ??
  2. Randomjim
    Randomjim Active Member
    2,752
    Mines an ADR. I think it's the late '97 onwards naturally aspirated 1.8's.
  3. Broken Byzan
    13,235
    464
    My old 98 was an ADR engine before i put the turbo engine in. Thinking about it, the a3 never came with an ADR engine, so it must have had a head swap at some point during its life
  4. 951
    951 Member
    530
    So will any 1.8 n/a head fit or does it need to be the correct code ??. Where is the code on the block as it may have had a complete A4 engine fitted prevoiusly and not just the head.Ive had another look at the engine (bottom end) Has AGN stamped on it !!
  5. Siena
    Siena Active Member
    2,626
    A3 or A4??
  6. aragorn
    17,896
    690
    sounds like its an AGN motor that someones fitted an ADR head to, the question is: if the head has already been changed, and now its up for sale again with more head gasket issues, whats the deal...
  7. 951
    951 Member
    530
    Its an A3, we dont know the history of the car so no idea if the replacement head was faulty or not put on properly or maybe as they were different codes they might not of been compatable ??. If i can get it cheap enough i may take a chance on it and budjet for complete engine swap.
  8. Broken Byzan
    13,235
    464
    WOOHOO Another turbo conversion it is then... hehehe
