Adjusting Rear Coilovers...
leeds2592 Jun 24, 2013
  1. leeds2592
    leeds2592 When I grow up, I want a 964!
    1,399
    222
    Hi all,
    Decided I wanted to go a bit lower on the rear of my A3. I've got AP coilovers so the adjuster is at the top but when using the C spanner to adjust it, the whole thing spins including the black plate at the top! I've read that this is a common problem but not read of a solution.
    Any tips on how to adjust it? It's annoying me that the fronts are so easy to adjust but the backs are a massive polavour!
  2. TimG
    TimG Active Member
    942
    45
    Slightly late reply here, but ...
    Remove the adjuster and drill a hole in the side of the threaded piece (at the base, not in the threads!). You will now be able to insert a screwdriver into the hole and prevent them from turning when you adjust them. I had to do this on my FK's.
  3. stuartm
    stuartm Active Member Team Monsoon VCDS Map User Audi A4 Audi A3 Audi Avant Owner Group Black Edition S-line owners group TDi Manual
    286
    42
    I put my adjuster at the bottom and bolted it to the swing arm, worked for me but is a bit of a nightmare if you want to adjust the ride height.
    Although it is only one bolt and you can get easy access to it.
