Adjusting lights
temp Jan 14, 2014
  1. temp
    temp Member
    74
    Right does anybody know which way to turn the adjusters on the lights and which one does what. Keep turning mine and don't think there is any change:-/
  2. :: blade ::
    :: blade :: Active Member
    343
    31
    ive heard about manual adjusters break easy so maybe yours have broke? i need to do this with mine at the weekend as my lights are shocking
  3. Wallm0nkey
    Wallm0nkey Member
    225
    If they aren't adjusting at all take the light out and remove the back you can see both the adjusters pretty well to see if there is an issue. Mine had a broken motor clip and the left adjuster had been wound totally out so wasn't doing anything but I managed to realign it and get it working.
    If they are auto leveling you need vcds to set the new home position when it's correct or they will adjust back.
  4. rupe
    rupe A3 TQS In Devon
    255
    35
  5. temp
    temp Member
    74
    Thanks! My lights are not electric adjust they are manual with 2 turning things on top of the light like little white plastic screw holes. Think passengers side light is knackered will not adjust at all but need to lift drivers side up. Find myself driving with full beam on.
