Adjusting front s line bumper
tuffy Apr 9, 2013
  1. tuffy
    tuffy Member
    314
    13
    Hi guys.
    Im sure i saw a thread somewhere, which i cant find now, that its possible to adjust the gap where the the bumper meets the bonnet either side of the grill, i have around a 15mm unsightly gap
    I think its possible to close this up, but does the bumper need to be totally removed to do this??
  2. Joe_Murphy21187
    Joe_Murphy21187 S-Tronic
    1,064
    71
    Yes. You need to remove the bumper and then adjust the two supports which it sits on. They are threaded I believe and you just need to turn them the right way.
    Quite a few guides about the place if you give it a search. Often paired with changing headlights (bumper-off job)
  3. sidibear
    sidibear Looking for Zombies !! Staff Member Moderator Audi A4
    2,320
    768
    I need this done on mine, but can't do it myself. Anyone fancy a go for beer tokens?
  4. hades-
    9,481
    646
    its easy try it yourself
  5. Wrath
    Wrath Well-Known Member
    1,196
    41
    Largely gave up trying to fix mine, just couldn't quite do it and have the lights fit in :(
  6. Tiffy
    Tiffy Active Member
    363
    89
  7. tuffy
    tuffy Member
    314
    13
  8. sidibear
    2,320
    768
    I have a spine issue.
  9. Tiffy
    Tiffy Active Member
    363
    89
    Tuffy...
    I used a long bar and torx bit like in the first picture....tyrned and the bumper rose up a bit....job done
  10. NOZ
    NOZ Active Member
    212
    33
    so you just insert the torx and turn to adjust the height HMMMM sounds to easy to be true ! what size torx is it ?
    thanks in advance
  11. southylad
    southylad Active Member
    544
    is this possible on the 56 plate s line bumper as the one in the guide loocks like a facelift 09 onwards?
  12. Tiffy
    Tiffy Active Member
    363
    89
    Exactly what i did......I Think it was a T20 or 25
  13. Rastamouse
    Rastamouse Welsh Audi Nut
    396
    19
    Did mine not long ago ,quite straight forward,believe it was aT35 torx i used.bout a set of 4 long series torx screwdrivers from the bay for bout a fiver,did the job a treat. Heres a few images. Of mine before and after adjusting.
    http://http://www.audi-sport.net/vb/showthread.php?t=172632
  14. NOZ
    NOZ Active Member
    212
    33
    so i set about mine yesterday, got all the necessary tools etc got the right side sorted all nicely fitting perfect, till i went to adjust the other side and found that the torx screw had been rounded off by obviously the previous owner, so back to the other side and back to adjusting it. So although now its not how i want it to sit but at least the gaps are now matching.So next time the bumper comes off i will see about replacing the said torx.
    Anybody thinking about adjusting the bumper it really couldn't be any easier clockwise to raise, anti clockwise to lower simples !!
  15. sidibear
    2,320
    768
    Just had a look at mine and cannot see the adjusters, bumper lights and grille are all in place. Am I missing something or do I need to start taking bits off to see them?
  16. Paul B7
    Paul B7 Active Member
    622
    34
    I am with you Sidibear, can't see the adjusters on mine either ?
  17. Wrath
    1,196
    41
    You need long torx bits. There are two holes, one either side of the grille looking down on it with the bonnet up.
  18. Paul B7
    622
    34
    I'll check mine out tomorrow with a torch ..............
  19. RMH1A4cab
    RMH1A4cab I'm in Cruise control
    551
    19
    sidibear likes this.
  20. sidibear
    2,320
    768
    Yay, found the hole and poked a stick in it and found I need something about 8" long (Cue carry on type innuendo jokes).
    What size bit do I need?
  21. NOZ
    NOZ Active Member
    212
    33
    that's the link i used perfect :yes:
  22. Paul B7
    622
    34
    Found them !
  23. jdp1962
    jdp1962 Grumpy Old Moderator Staff Member Moderator TFSI Owners Group Team V6 Gold Supporter Team Tornado Audi S4 quattro Black Edition s tronic
    8,326
    2,861
    Ooooh, Matron!
  24. tuffy
    tuffy Member
    314
    13
    Had the car in the workshop yesterday, had a quick look..... looks like one of my adjusting bolts is actually missing!
