Adjusting Adaptive Xenon headings for driving in Europe
h5djr Aug 18, 2009
  1. h5djr
    9,186
    1,578
    If, like me, you have the new Adaptive Xenon headlights the proceedure using VAG-COM for adjusting these for driving in mainland Europe is slightly different from the normal Xenons.
    With normal Xenons you Select Control Module - Select 55 Xenon Range - Select 10 Adaption and change Channel 10 from 0 to 1.
    With Adaptive Xenons you again Select Control Module - Select 55 Xenon Range - Select 10 Adaption but then you need to change Channel 23 from 0 to 1.
    If you do not have access to VAG-COM it is something that will have to be done by a dealer using their VAS 5051 diagnostic equipment.
    I have now updated my notes in the following post in the FAQs accordingly.
    http://www.audi-sport.net/vb/showthread.php?t=33492&page=2
  2. brissett
    brissett Member
    41
    does this mean i can alter my bi-xenon headlights for driving in europe using vagcom?, and thus passing my lights test in germany without having to fork out on continental headlights?
  3. KoFidee
    KoFidee S-LINE
    149
    Iam pretty sure on My car I can change the headlights under the car options settings on the dashboard B8
  4. h5djr
    9,186
    1,578
    No I don't think so. All the 'temporary' change does is basically to lower the beams to stop you blinding other drivers. Ok for a holiday, especially as generally not much night driving will be done. But I assume you car has to pass the BFG Lighting Test. In this case, as I understand it, you will need to change your headlights for a pair of continental ones.
  5. h5djr
    9,186
    1,578
    I understand this is possible on some models, but it's not yet possible on my 2009 A3. Perhaps when the new A3 comes out in 2011 it will be included.
  6. KoFidee
    KoFidee S-LINE
    149
    Just home checked car setup and exterior lights can be adjusted! for driving on the right.
  7. brissett
    brissett Member
    41
    what about the rear headlights?
    ive just spoken to my bfg lights guy and he says i need to order rear light clusters because the reverse and fog lights are on the wrong side! :(
  8. Cockney Boy
    Cockney Boy Member
    483
    Yes if you have the UK version, it will have handed rear clusters (not on all models tho) so if this is the case on yours, then you will have to change them if you intend to live on mainland Europe, but not for a short stays.
