Adjustable rear tie bar installation
jomnhta Oct 2, 2007
  1. jomnhta
    jomnhta Member
    60
    Hi all, I just received my adjustable tie bar from ECS and would like to put it on my S3 ASAP. But I wonder should it replace the upper tie bar or the lower one since I found two on each side under the chassis.
    Any input would be welcome. I am sure someone on the forum have them installed. Thanks.
  2. jojo
    28,859
    3,518
    The lower ones are the preferred choice methinks, but there's a few members that have changed the top ones, doesn't make much of a difference I think.
  3. ChriS3
    ChriS3 hud at ye bam
    2,239
    27
    Jim at Star Peformance explained some reason why its best to have them on top. Can't remember it now, Sorry. He was in a good mood and have a bit of a tuning rant. Could be something to do with the driveshafts and pushing the hubs out. Or something to do with it adding a weaker link in the system and should be less affected on top.
  4. Ess_Three
    Ess_Three Active Member
    5,383
    14
    Jim and I went thtough all this too, as mine were the first set he'd fitted...
    In my view, the top is where they should go.
    It means you are keeping the rear CVs un-loaded, rather than pulling the hubs further in and potentially loading the CVs, and I'm more keen of having the solid arms on the bottom as I assumed they'd take more of the loadings
    The bottom is the easier place to fit them though...so many fit them there.
    I don't think there is a definitive answer...
  5. ChriS3
    2,239
    27
    Cheers Glen. I wasn't as far off as I thought I'd be.
  6. Ess_Three
    5,383
    14
    Correct on both counts Chris...
  7. jomnhta
    jomnhta Member
    60
    Alrite, thanks mate, I will get it replaced the upper bar.
    But would it be more difficult to adjust to use it as the upper bar?
  8. Ess_Three
    5,383
    14
    Yeah, slightly more difficult to adjust...but you should only need to do it once, or very infrequently.
    It'll be harder to fit too...you have to take more 'stuff' off, or move more out of the way.
  9. jonS3
    jonS3 Member
    719
    dont mean to hijack this thread, but I want to change the springs and dampers on my S3, how low can i go without the need to fit adjustable tie arms?
  10. Ess_Three
    5,383
    14
    Nothing...
    Even the quattro GMbH cars are known to have adverse wear issues and they are 10mm lower than standard.
    Basically, if you lower it at all, you should fit adjustable tie bars...not only will you get improved tyre wear, but a far better drive, more predictable handling, better traction etc. Well worth doing.
  11. jonS3
    jonS3 Member
    719
    cheers Ess_Three
  12. s3ollie
    s3ollie Member
    762
    i fitted my bars on the top only because it would widen the rear track by pushing the tops out rather that pulling the bottoms thus reducing rear track
