Adding Electric Folding Mirrors
Anthony566 Mar 23, 2014
  1. Anthony566
    Anthony566 Active Member
    732
    111
    43
    How do I find out if I need to replace the door control box to add Electric Folding Mirrors?? And has anyone done this ??
  2. X_Splinter
    X_Splinter Member Audi A4
    90
    22
    Yeah it has been done, I remember somebody posting a link to a tutorial of how to do it.
  3. Anthony566
    732
    111
    43
    Yeah I did find this one with lots of detail :-
    AudiEnthusiasts Folding Mirrors
    But no detail about the door control unit so not sure if the one that is already in my car will be ok or will I need to change it.
  4. hades-
    9,482
    646
    iv done it 3 times now
    and scanned loads and loads of b8's
    and ill say every 1 needed the door mods
    but its quite an easy retro fit to do.
    its quite confuseing about what door control moduals you do need aswell and there ££££ from audi
    dont go on the part numbers alone go on the small pictures on the unit aswell or you could buy the part number needed and they wont work.
  5. Anthony566
    732
    111
    43
    Ok thanks for that bez101, I was looking to buy a set from a 2012 B8 facelift the same as mine as these come with the control units and the door control, how easy is it to swap the covers on these as the ones im looking at are black and my car is white.
    I am also assuming that the covers on my none electric folding ones will fit the electric folding ones ??
  6. hades-
    9,482
    646
    covers are tight and just need to take your time with them but easy to do
    yes they covers will fit the folders there is 2 diffrent caps tho one with flasher at the bottom one with flasher cut into the cap
    if these are the ones you are thinking of buying AUDI A4 S LINE B8 2013 MODEL FOLDING DOOR MIRROR SET KIT | eBay
    then get a close up picture of the control units as when i went to buy the units were wrong parts
    you also need the door handle and light ring to put the switch in
  7. Anthony566
    732
    111
    43
    They are the ones I was looking at ...
    Do you have a photo of what they should look like ?
  8. hades-
    9,482
    646
    i do on my laptop but might not get near that for a good few days
  9. hades-
    9,482
    646
    look in the top right corner the 4 boxes this is a unit that will work the folders the boxes need to be the same as in this picture
    if there not the mirrors will NOT work
    Anthony566 likes this.
  10. Anthony566
    732
    111
    43
    excellent .... thanks for that I was going to drop in and have a look at them to conform that they are the same style as mine s I can also check the door control units.
    Also how would these show up on my vcds ?
  11. hades-
    9,482
    646
  12. hades-
    9,482
    646
    what do you mean show up on vcds ?
  13. Anthony566
    732
    111
    43
    I have a vcds can I see from that if the units in my car will control folding mirrors ? ( Just got this from NHN )
    Also I see in the photo the boxes are solid ....
  14. hades-
    9,482
    646
    no dont go off vcds as above the part number could be the same and the 4 boxes diffrent
    you need to remove door trim and look at the boxes
  15. Anthony566
    732
    111
    43
    Ok ... I will be taking the door covers off next weekend as I have some puddle light looms to fit so can check then.
    Thanks for the advice it really is appreciated.
    :respekt:
  16. Jamie-S
    Jamie-S Member
    274
    17
    I have some spare modules too if you don't have one yet
  17. Anthony566
    732
    111
    43
    Thanks Jamie ... if I find some without the modules I will take you up on that.
  18. hades-
    9,482
    646
    do you have both ?
    how much and a picture please
  19. johnnythepie
    johnnythepie Well-Known Member
    2,242
    76
