Adding Cruise Control
Bash_A3 Apr 5, 2007
  1. Bash_A3
    Bash_A3 Member
    233
    A friend of mine at work has bought a 2nd hand cruise control stalk on ebay & bolted it on his Passat, changed a setting in the ECU and it works :)
    has anyone else tried this on their A3/S3?
  2. garratt83
    garratt83 Member
    244
    No but if you do a search there are some posts on this mod and where to buy it and I believe it is possible.
  3. Bash_A3
    Bash_A3 Member
    233
    Thanks i've been searching but couldnt find anyone thats done it on the 8L, i'll keep looking!
  4. garratt83
    garratt83 Member
    244
  5. Bash_A3
    Bash_A3 Member
    233
    Brilliant thankyou! will give the guy in Wimbledon a try as its not far from me :)
  6. MattS5
    MattS5 Active Member
    619
    60
    Had mine fitted at APS
    £149
  7. Aky
    Aky Aky
    1,512
    Is it a difficult job to do yourelf? I'm just not sure where the loom goes to??
  8. claudefrog
    claudefrog Member
    372
    the loom has to go right to the ecu, you have to fit 4 wires into the ecu... i done mine a few weeks ago, didnt take that long really :)
  9. garratt83
    garratt83 Member
    244
    How much did it cost you?
  10. dantheman1986
    dantheman1986 Member
    262
    hi has anyone got any of the part numbers needed to fit all this? ie new stalk and looms ets
  11. claudefrog
    claudefrog Member
    372
  12. dantheman1986
    262
    i thought you need 2 looms and one of them had to be made up custom?
  13. claudefrog
    claudefrog Member
    372
    i just made it up from an old civic wiring loom, but anyone else doing it will have to buy the connectors to go into the connector plug behind the fuse box
  14. chodecz
    chodecz New Member
    10
    Hi guys, I read up on all that thanks for the info.
    I'm going to be buying a '98-'99 A3 1.8T. I presume it wont have drive by wire, so is CC a complete no-go then??? :( From what year did 1.8T have drive by wire?
  15. netman
    netman It's me!
    Interested in this - is there any more concrete info on when DBW starting being used on the 1.8T? Facelift onwards perhaps, or at some other more random time?
    Thanks,
    Steve
  16. claudefrog
    claudefrog Member
    372
    check on yout inlet manifold to see if its dbw or cable.. not hard to miss a cable goign to throttle butterfly
  17. s3ollie
    s3ollie Member
    762
    or EPC will light up on the dash when the ignition is on. my cars a 99 and it is DBW
