Adaptive xenons on led drl unit
*Müllërz Jan 16, 2012
  1. *Müllërz
    *Müllërz REVOlutionary
    479
    Hi all
    I dont know if i have adaptive xenons or bi xenons...
    Can anyone help on how to identify the difference other than whilst driving?
  2. warren_S5
    warren_S5 Moderator Staff Member Moderator VCDS Map User
    7,210
    2,483
    If you have adaptives when you start the car they will do an up / down / left / right 'dance' as part of the start routine.
    If you have bi-xenons they just go up / down as part of this procedure.
  3. *Müllërz
    479
    and if it does neither than there is an issue with the auto levelling?
  4. warren_S5
    7,210
    2,483
    I'd say so yes. My 8P2 and 8P3 had adaptive and bi-xenons respectively, and you can hear the motor moving the lights if you listen carefully.
    That said, I'm wondering if it only happens when the lights circuit is active (e.g auto lights on and car senses it's dark).
    Park face on to a wall at night, turn on ignition and start car with auto lights set to on and see if it happens!
  5. andywaddy
    andywaddy Member
    133
    Warren - I have adaptive xenons but I don't recall them ever doing a left and right start up procedure? On mine they go from down to up and that's about it I think. They're turning whilst cornering so all is good on that front.
  6. h5djr
    9,240
    1,628
    Mine are the same. Just go up and down during the start-up procedure. I always notice mine because the car is kept in my garage and when I start-up the auto-lights come on and the xenons go up and down.
  7. warren_S5
    7,210
    2,483
    Interesting, Im sure my S3 lights did a little left right twitch. If you drive in the fog you can physically see it.
    A certain way of telling is how deep the headlamp unit is. My 07 car lights were much longer and Forge had to make a special catch can bracket for them. My new headlamps are nowhere near as deep.
  8. RedDejavu
    RedDejavu Well-Known Member
    1,801
    333
    Mine go up and down only as well.:crying: so mine are not adaptive then are they?
  9. warren_S5
    7,210
    2,483
    :sadlike:
  10. andywaddy
    andywaddy Member
    133
    Do they turn whilst you're cornering? If yes...then they're adaptive right?
  11. *Müllërz
    479
    My Car is parked in the garage on a night and upon starting in the morning i havnt noticed the light move in any directon yet
    I still have the pre facelift headlight switch which had halogen lights,so i think that could be one reason and the auto levelling not being picked up by my current ce,could be wrong
    On the new switch there is no option to change headlight beam manually?right?as it is auto?
  12. RedDejavu
    1,801
    333
    no they dont.... is it hard to retrofit? I assume new lights and some coding maybe?
  13. NHN
    29,295
    1,701
    It requires different headlights, rewiring, different module & coding, all of which I can supply/fit :)
  14. NHN
    29,295
    1,701
    Have you actually fitted any levelling systems to the car?
  15. *Müllërz
    479
    Still need to get the right c/e wired to it nige
    Glad i dont drive ona night
  16. NHN
    29,295
    1,701
    Then that answers why yours dont work, its not just the CE aswell.
  17. *Müllërz
    479
    Enlighten us sir :readit:
  18. NHN
    29,295
    1,701
    You didnt answer the question asked, have you fitted any leveling systems to the car as yet, if not then they wont work no matter what ce modules fitted.
  19. RedDejavu
    1,801
    333
    Ah..... sod it then sounds like big bucks for small change
  20. NHN
    29,295
    1,701
    I personally dont call it small change, they're great on the road.
  21. warren_S5
    7,210
    2,483
    THey are good, I just didn't do enough night driving to warrant them on this car.
  22. *Müllërz
    479
    yep fitted nige
  23. One Spoke
    One Spoke Member
    267
    My 07 S3 has adaptive bi-xenons and they definitely do a left/right and up/down dance when I start it with the lights in auto mode. Warren - you're not going mad (yet!)
