Adaptive lights
Sock Sep 11, 2011
  1. Sock
    Sock Shark in a Goldfishes clothing
    576
    Could do with some help on this :)
    Will lowering the car have a noticeable impact on where the lights shine on the road as I can only see about 30 feet max infront of the car when on dark roads? ( main beam is fine but when following a car I feel I am driving blind lol )
    Also how can you tell if the adaptive lights are working as mine don't seem to move when cornering? ( they do dip when you first start the car )
    Car was checked with Vagcom last week and has no faults showing?
    Cheers :)
  2. Khufu
    Khufu Well-Known Member
    5,704
    31
    If you lower your car you will need to have your headlights re-aligned.
    you can test normal xenons for up & down using VCDS, perhaps with adaptives have an option for left & right too?
  3. Sock
    576
    No probs will get the hight checked
    Is the move from left to right when turning very noticeable? When I turn on a corner the lights just stay in line with the car?
    If I was stationary and turned tge wheel in full lock would they still move?
  4. NHN
    29,328
    1,708
    It does a dance at car start for n/s/e/w, so if yours go only n/s then I'd get it onto vcds & adapt them to check its all ok.
    As Ewan says, if lowering readapt them to suit.
    There is an adapt channel that you san set for showroom mode that can test the adaptives, it will only be noticeable on the country roads, as it wont be noticeable at speed.
  5. Sock
    576
    Ah right ok,
    I don't have vcds but will nip into audi and ask them what they think being as I still got warranty
  6. NHN
    29,328
    1,708
    Sockkkkkk buy vcds & stop lying to yourself, you need it in your life, if you can afford to run the S3, you can certainly afford vcds :p
  7. Sock
    576
    Lol how much is it?
  8. Sock
    576
    Ignore that just saw it's £250 ish?
    Might have to invest
  9. NHN
    29,328
    1,708
    Considering the hassle of going to audi etc, surely thats a no brainer :)
    On shelf, ready to post tomorrow for tuesday delivery.
  10. Sock
    576
    Lol I will remember that but got a couple of other things to buy first :)
  11. Yaks
    Yaks Member
    181
    Just to clarify the above point which I don't think has been answered - adaptive lights don't turn when car is stationary, they only work above about 10mph, so you can't test on the driveway.
  12. NHN
    29,328
    1,708
    Can with vcds lol
  13. -Ju-
    -Ju- Well-Known Member VCDS Map User Team Panther Audi S3
    2,210
    399
    Are you sure you have adaptive lights, sounds to me like you don't tbh. They should do the side to side test when first turning on and you can definitely tell when driving in the dark, infact it's pretty weird at first!
  14. Sock
    576
    Well it was advertised with adaptive lights when I bought it but never thought to check?
    They go up and down when I first start the car but not left to right?
  15. NHN
    29,328
    1,708
    Just check the part number on the headlight labels under bonnet, that will advise us.
  16. Sock
    576
    Will do it in the morning, cheers folks
  17. Sock
    576
    Ok so I hope this is the part number? 8P0 041 003 AA
    Don't know if it helps but I took a picture of the lights too?
  18. -Ju-
    2,210
    399
    Mine are adaptive and say
    8P0 941 030 AB drivers side
    8P0 941 003 AB passenger side
  19. Sock
    576
    Mine say 003 passenger side and 004 drivers side? Do your do the N S E W dance on start up?
  20. -Ju-
    2,210
    399
    Yes mate they both drop down then side to side and then back up!
  21. Khufu
    5,704
    31
    AA are just normal BI-Xenons :-(
  22. Sock
    576
    Oh right, well that's cleared that up
    Bit pissed off it was advertised with the adaptive lights but hey ho, just one thing less to go wrong lol
