Adaptive headlights - don't think mine are working?
jet_andy Jul 9, 2013
  1. jet_andy
    jet_andy Active Member
    167
    30
    Can anyone else who has the Adaptive Headlight option tell me if the movement of the beams is clearly visible when driving at night?
    I had a similar feature (ie swivelling xenons) on my previous car (Peugeot) and it was quite clear to see the beam move with the steering, particularly when on high beam.
    On the A3 I just don't see this. Going by the description here, it should be pretty much the same.
  2. NHN
    29,284
    1,695
    All comes down to road speeds, turns etc, its most noticeable on village roads tbh, slow turns & just pull up to a junction & turn wheel to 1 side just as you pull up & see if lights swing over.
  3. jet_andy
    167
    30
    yes - that's pretty much as they operated on the Peugeot. I know you can't sit in the drive and test them. I was out last night going through some slow sharp bends and couldn't see anything move. On the Peugeot couldn't help but notice.
    It's in for the A/C (again) Thursday so I'll ask if it's something they can check. Would there be a test function they can use, or have to put it on the rolling road?
  4. jet_andy
    167
    30
    By the way - I do have the option ticked in the MMI menu - before anyone asks!
  5. NHN
    29,284
    1,695
    What's the 8V part number on headlights?
  6. jet_andy
    167
    30
    Will check. BTW - checking with the Option codes decoder says I have "8Q5 = Headlight-range adjustment, automatic/ dynamic with dynamic bending light (AFS 1)"
  7. jet_andy
    167
    30
    8V0941032 (right)
  8. RossR
    RossR Active Member
    501
    122
    43
    Don't they do a calibration danced when starting up or is that only older models?
  9. jet_andy
    167
    30
    Yes they do, but that's the auto height adjustment that all xenon's have (regulations I think).
  10. cemerson
    cemerson Well-Known Member Team Cosmos quattro Audi A3 S-line owners group TDi DSG
    4,371
    1,063
    The old ones did up/down and side/side on startup I think, hence the 'dance'. Wonder if it's something that can be set via VCDS, much like the needle sweep - after all, both serve the same purpose - checking range of movement.
  11. -Ju-
    -Ju- Well-Known Member VCDS Map User Audi S3
    2,129
    338
    I know the range of sideways movement on my R36 is far more than my old 8P S3, maybe that's just how they are.
  12. V00D00
    V00D00 Member
    57
    Take your car to a covered below ground car park (dark) and drive it towards the walls, turn and you will see if the lights swivel. I have adaptive lights on my 8P, I was also very unsure if they worked.
    Disclaimer: Please don't crash into the walls. LOL
    SJW and jet_andy like this.
  13. jet_andy
    167
    30
    Been out tonight and for the life of me I cannot see any movement. The old Peugeot was easy to see and clips of Audis on YouTube look obvious too.
    When they start up, they do the normal up/down adjustment, and watching carefully I also noticed the a tiny left/right movement. I'm sure they are fitted, just not sure they're working right.
    Hopefully they can check it out whilst its at the Dealer tomorrow.
  14. jet_andy
    167
    30
    Whilst car in for the A/C (see other thread) they say they've checked them and there's no fault, although apparently they can only test at night?
    I'm not convinced
    a) that they are working correctly
    b) that there is not a test/demo mode to check them whilst stationary
    I'd be interested to hear from others who've got them as to how much movement you can see, and if anyone knows if there should be a test mode, as there certainly is on other models.
    cheers
  15. A3sportbackMark
    A3sportbackMark Active Member
    711
    230
    43
    Andy, I cannot comment at this stage, as I don't have my car yet! However I am interested how this pans out, as when i get my car i wouldn't know if the adaptive lights work or not.
  16. jet_andy
    167
    30
    Had cause to be out Saturday night - headlamp test then after being told they were OK.
    So here's the funny thing - they definitely ARE working OK....now.
    Audi dealer claimed they'd checked them out and there were no error codes and they did the self test OK. When I went out I didn't have to peer into the light beam to see if it was working as I turned the wheels - it was plain to see they were working. Which is why I don't understand it, I always knew what to expect because I had them on my previous car, but the first couple of times I went out at night with the A3 I could not for the life of me see any movement.
    Either they found something wrong - like being disabled in software or something, fixed it and didn't say, or there was a glitch and running them through the test system reset it.
    I'm puzzled, but glad they are working.
  17. A3sportbackMark
    711
    230
    43
    Thanks for your explanation Andy, and pleased its working correctly for you. It's one of the many things I will have to check when I get my car......it will take me a few weeks to see if everything is working right!
  18. AJB
    AJB Active Member
    175
    43
    I tried mine for the first time last night, and you can seen them follow the road on dipped beam on country road corners. The handbook seemed to imply that they don't turn if you've got the headlights switched to ON rather than to AUTO. I wonder if that's something to do with it? Maybe you need to be on Auto.
    It also implied that the adaptive headlights might be affected by Driver Select (maybe more adapatation or faster adaptation in dynamic and less in comfort) but that doesn't really make a lot of sense...
    I haven't had a chance to play yet other than headlights in auto, driver select in auto, dipped beam, country road, and I could see them follow the road.
  19. Karl Alesbury
    Karl Alesbury Active Member
    149
    30
    I was driving on Sunday night, and could plainly see when I steered one full turn of the wheel, the side of the car lit up straight away. It's very noticable if you're looking for it.
  20. Richyboyp
    Richyboyp Member
    156
    23
    So I have adaptive lights. Mine work fine! Although at 1st I wasn't sure. The headlights only move when the car is moving, I can't just remember the speed but it is stated somewhere. Then the driver select affect the motion too. The cornering lights as some people mention are different again. I will stand corrected but I'm sure all with fogs have cornering lights. This is where the fog light to the direction you turn will come on and then fade out. Also the indicator will bring it on to at slow speeds. My headlights dance when the ignition turns on. All xenons will calibrate on start up as they self adjust. I can see mine go full circle.
  21. mjcourtney
    mjcourtney Well-Known Member Team Mythos Audi A4 Audi Avant Owner Group S-line owners group TDi
    1,644
    498
    I don't believe the A3s have cornering fog lights. Lots of VWs do, but i've not seen any A3s do this.
  22. AJB
    AJB Active Member
    175
    43
    You're right, the cornering lights are different again (but I think come with adaptive xenons). They don't use the foglight, though. There's a separate halogen bulb in the headlight assembly which has a reflector pointing slightly outwards - that's what's used for low speed sharp corners, or when the indicator is on at low speeds. I always think the foglight position ones look slightly strange (as if 1 foglight has broken), so I was really pleased when I realised yesterday evening that mine has a cornering bulb, but not in the foglight position!
    cemerson likes this.
  23. Richyboyp
    Richyboyp Member
    156
    23
    I'm so glad it's in the headlight, that I didn't know, I just assumed it was the fog light as that's where it looks like from the drivers seat. I agree the one fog coming on looks a bit tat. Happy now. Ill be looking at that tonight :)
  24. RossR
    RossR Active Member
    501
    122
    43
    My wifes Seat uses the fogs as cornering lights and it is quite handy for turning into the driveway. It does look a little odd I'll admit, although they do fade on and off which helps. To be honest I'd rather they designed them as cornering lights, and didn't have front fogs. If I get a VCDS cable I'll be looking at enabling cornering lights using the fogs - they look to have a fair lighting pattern for this.
    mjcourtney likes this.
  25. jet_andy
    167
    30
    I had another thought about mine not working (although never posted at the time). Earlier I'd had the rear view mirror fall off and had had to unplug it completely until it was fixed. At the time I unplugged it I got an error message relating to auto lights and wipers - understandable as the sensors are in the mirror. Whilst with no mirror I of course couldn't use Auto lights, but knew that the cornering lights would not work in manual mode.
    I still had the problem after the mirror was re-fitted. I think that when I went back they realised that the auto lights needed some sort of reset due to the mirror being unplugged, but it had not been done at the time. Rather than admit it wasn't done at the time they did it on this visit and said nowt! I don't believe in coincidence so I'm sure the two are related...
  26. baldrick
    baldrick Member
    49
    I have adaptive lights on my Beemer, though I must say I am more impressed by the the lighting output than the adaptive side. A great novelty but I am not sure cornering and moveable lights are that essential.
    Back in my youth I did some road rallying with a huge pair of Cibie Super Oscar long range lights bolted on, Now it seems modern car's standard headlamps can perform as well if not better and yet to try LEDs...
  27. PembsA3
    PembsA3 Active Member
    276
    71
    Something I noticed on my 'old' 8P with adaptive lights - only the headlight on the inside of the turn moved - the other stayed pointing straight ahead, so you have to be looking at the inside beam to check they are working...
  28. Richyboyp
    Richyboyp Member
    156
    23
    I've just been out in mine, I'm pretty sure that both the lights move.
  29. cemerson
    4,371
    1,063
    I had a go at the variable range control today, although I was in town so not sure it really did much - turned it off after a short time in case it wasn't working and I was dazzling people. Will have to give it a go on a darker road I think to test it! First time out in the dark tonight though, the Xenons certainly work well, but I didn't go fast enough to trigger the adaptive function
  30. jet_andy
    167
    30
    You only need to do 18mph...
  31. cemerson
    4,371
    1,063
    Do you? Thought it was much faster
  32. Fragup
    Fragup Member
    462
    185
    This is from Audi website and states adaptive lights work from 10 km/h to 110 km/h, not sure if this is exactly what you are checking, and is not specific to A3 but gives you an idea that works at low speeds.
    adaptive light > Glossary > advice > Audi Worldwide
  33. jet_andy
    167
    30
    Oops..my mistake, it's cruise that starts to work at 18mph...as Fragup says its 10kmh (or 6mph)
  34. cemerson
    4,371
    1,063
    What are the best conditions to see the adaptive lights in? I'm not so convinced mine are doing anything now...
  35. jet_andy
    167
    30
    In a narrow road with high hedges and sharp corners. Or just wiggle the wheel slightly when you're following something that you can see the top of your dipped beam on.
  36. cemerson
    4,371
    1,063
    Checked my MMI - Drive select is in auto. I did see them wobble slightly side to side when I started the car for a test - how much are they supposed to move? It was only a tiny amount. Perhaps I should put on Dynamic mode and give it a go.
  37. jet_andy
    167
    30
    Does Drive mode matter? (I do drive in Dynamic and can't remember if they worked when I was in Auto).
    You have got Adaptive lights selected in MMI? And start up test is a tiny wobble!
  38. cemerson
    4,371
    1,063
    There is something in there for 'cornering light' under individual settings, but that could refer to the static cornering light. I'll take a proper look over the weekend when I should be on some dark roads (going to Wales), which I haven't really done yet - been trying to look at it under street lighting in town. Also want to test the variable range lights for high beam as well.
  39. jet_andy
    167
    30
    You do need to turn the Adaptive function on, under external lighting/auto headlights.
  40. cemerson
    4,371
    1,063
    Yup, done that already!
